Power Loss At High RPMs
Old Feb 19, 2010 | 08:55 AM
Polish Person's Avatar
Car: '91 Trans-Am GTA
Engine: 305 5.0L V8
Transmission: 4-Spd Auto
Alright, so I have a '91 T/A with a 305 and a 4spd auto and I'm having horrid power loss issues lately. The car hardly accelerates in any gear.
The problem first started a few days ago on the highway when I was in fourth and going about 70 and went to pass and the car dropped to third and just wouldnt accelerate. Now it hesitates in any gear. Starting from a stop light takes me forever to get up to speed.
At first I thought my third gear was screwed becuase it is the most used, but now I'm starting to think maybe its a fuel delivery problem. The car holds speed fine, but around 3,000 RPM, the engine just wont push the car in any gear and its sluggish any lower.
Steady gas in fourth will eventually get my up to any speed but once again, it takes a long while and if the computer drops it to third then I'm screwed.
Any ideas?
Old Feb 20, 2010 | 07:14 AM
flying89's Avatar
Car: 1989 Camaro RS Drag Car
Engine: SBC 388 Stroker 93 pump gas
Transmission: Built turbo 350 3500 tci converter
Axle/Gears: Stock axles 4.10 gears
Re: Power Loss At High RPMs
Could be a motor issue lack of power from battery or lack of fuel to where car boggs and wont go. might be some things to check before you go deep into rippin her apart
Old Feb 23, 2010 | 09:03 PM
Engine: 305 5.0L V8
I drilled a hole through my CAT and the problem faded noticeably. I think I might just remove it until my next inspection or atleast unbolt it until I can get a high flow unit. I do believe it's clogged
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
Bradsaundry
Aug 12, 2015 12:34 AM
