What type of car does This SHIFTER fit?
I got this off ebay, the guy said it would fit a thirdgen camaro but the base is too big. There is no part number on it. Do you know what type of car and year it is for? How do you tell if it's T5 or T56 ?
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: What type of car does This SHIFTER fit?
Looks like a Pro50 T56 shifter (also fits the mustang T3550 or such iirc)
Are there Pro50 markings on it?
Definitely not a thirdgen Camaro/Firebird T5 (Square shifter base). I remembered that the Mustang T5 used a similar shifter base, so it depends on the piece.
That looks identical to the Pro 5.0 on my T56. The one on the T5 in my Mustang looks the same, just with a different handle and the mounting holes in the base are drilled at the corners instead of 1/2" narrower. The Camaro T5 uses a much smaller shifter base then the Mustang.
The T56 shifter bolts holes are about 4.85" x 2.15" on center. The base will over hang the shifter mount so you can't use any measurements from that.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
