9 inch pinion offset question
Old Feb 28, 2010 | 06:09 AM
holeshotkid's Avatar
Just picked up a 9 inch rear. It is the correct length so I don't have to shorten it. I did notice however, the pinion is offset 2 inches to the right (passenger) side from the overall center of the housing. Is this going to cause any problems running with that amount of offset?
Old Feb 28, 2010 | 09:59 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9 inch pinion offset question
no
Old Feb 28, 2010 | 10:10 AM
Thank you for the answer. I didn't think it would but before I started ordering parts, I thought I would check.
Old Feb 28, 2010 | 06:08 PM
big gear head's Avatar
The Chevy rear end has the pinion offset 1/2 inch to the right from center, which means that the pinion is one inch closer to the right end than the left. If you have enough clearance in the drive shaft tunnel for the amount of offset that the Ford has then it will be all right. If the drive shaft is going to hit the side of the tunnel then you need to make some modifications.
Old Mar 1, 2010 | 10:52 AM
Thank you for your response as well. I believe the only clearance issue I might have is with the exhaust. I can fix that..
lt1z350
Sep 29, 2015 01:50 PM
NiG
Sep 2, 2015 06:54 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
