Help, installed ring gear on posi and
Old Mar 6, 2010 | 03:09 PM
Superjustin13's Avatar
This is a 3 series Zexel Torsen, with GM 14092111 7.625" Gear 3:73, bought it and the guy said it was a 3 series gear.
Now i went and snugged the bolts up and the cross shaft wont go in, Did the guy lie to me and are these gears just to tall?
Gears to tall? its a 3.73- part number dosent come up with much, but its from a S10
Old Mar 6, 2010 | 03:13 PM
big gear head's Avatar
Re: Help, installed ring gear on posi and
I would have thought that a 3.73 would have worked fine. When you get to about 4.56 you need a special cross shaft to clear the gears. I would install the unit in the housing and see if you are going to be able to get the backlash set without any problems. If you can set the backlash without having to modify anything then the gears are right. The cross shaft might need some slight modifications. I've had to do this before, but not with a 3.73. Let me know if you can set the backlash and I'll tell you how to fix the shaft.
Old Mar 6, 2010 | 03:15 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
It looks like a carrier 2 gear !
Old Mar 6, 2010 | 03:17 PM
How could i modify it, i'd have to grind it down, which i shouldnt have too, and if i did grind it down, it would become sloppy.
Do i just need to buy new gears? this is bullshit, day of time to put this rear together..
Old Mar 6, 2010 | 03:18 PM
Yeah, but its a GM Gear, GM didnt make 3 series gears to fit on 2 series carriers
Old Mar 6, 2010 | 04:36 PM
You only have to grind a little bit of the shaft. Not all the way down, just a small amount. See if you can get the backlash set first.
Old Mar 7, 2010 | 07:25 PM
Anyone? It is a 3 series Zexel Torsen, and 3 series 3.73 GM gears
Old Mar 7, 2010 | 08:28 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Superjustin13!!
Anything bigger than 3:42 requires some "massaging" of the cross shaft/pinion block!!
Just a thought!! Can you remove the ring gear, then install the cross shaft/pinion block, then re-install the ring gear??
If you can't do that, what prevents you from doing that???
Thanks for pointing that out in your PM Superjustin13!! Never thought that far ahead!!!
Old Mar 7, 2010 | 09:44 PM
Hello Again Superjustin13!!
The pinion block "will" have to be clearanced a bit!! There is such a thing as a two piece one, but it's hard to come by!! SLP had one part # 64002, used for 4.10 or larger gears!! It probably would work in your case, but as I said hard to come by!!
just be careful, and only take off enough material from the pinion
block to get it to slide into place!!
I know that you can do a
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
