97 SS rear end
Old Mar 9, 2010 | 03:19 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
97 SS rear end
I want to upgrade up rear end in my 82 TA. I have a 9 bolt 3:27 in it now but I am finding it way to hard to find parts for. I am thinking of a 10 bolt and have read all the 10 bolt stickys...they are great by the way.
I found a rear end from a 1997 Camero SS, with 3:42 gears. Just wondering if this will work on my car other than the e brake. I wasn't sure where it was from a SS car if it would work in my TA
Thanks.
Old Mar 9, 2010 | 03:33 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 97 SS rear end
Is something wrong with the 9 bolt? If not, there's really no sense in changing it out for a 10 bolt. The 9 bolt rear axles have higher spline count and are actually considered to be a little stronger so unless you're having problems, you might be better off with what you have. Not to mention that a 4th gen rear swap means you'll have to compensate for the different wheel bolt pattern and it'll stick out about an inch+- wider on both sides..
Old Mar 9, 2010 | 03:41 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: 97 SS rear end
Bolt pattern is the same but it's almost 2 inches longer then you current rear which means you will have to run a different offset wheel unless you want your rear tires sticking out that far. You will probably also need a proportioning valve for the disc brakes unless your 9 bolt has discs now.
Mark.
Old Mar 9, 2010 | 05:45 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
Well no there is nothing wrong with the nine bolt. The reason I was thinking about this is....I wanted to go with 3:70 gears for one thing. The other thing is I wanted a posi rear. I talked to a guy from summit racing today and he told me They don't sell a possi unit for the 9 bolt anymore and I would be better to go with a 10 bolt.
Now I don't know much about these rear end. I am not sure if I have a worn out posi or a LS. Someone else told me I might be able to rebuild the my diff. I will post up some pics, maybe you guys can tell.
Old Mar 9, 2010 | 05:56 PM
Stephen's Avatar
Car: 87 GTA
Re: 97 SS rear end
While 9-bolts parts are less common to find, they aren't impossible to find. Since the 9-bolt is an Australian based axle and the R&P is still in use in Australia (last time I looked).....
A far as the 4th gen axle vs 3rd gen width......I'm annoyed by people using the term "stick out". The fact is that they will SET out further, but not STICK OUT. With 3rd gen 16" rear offset wheels, they will still be under the fenders. Almost flush, but still under them.
Don't choose to go with a weaker axle, unless there is NO option.
Old Mar 9, 2010 | 06:10 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
yes to me that doesn't stick out. I don't mind the look of that at all!
Old Mar 9, 2010 | 06:17 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
Here are some pics of my 9 bolt. How can you tell if it's a posi unit?
Attached Thumbnails 97 SS rear end-1.jpg   97 SS rear end-2.jpg   97 SS rear end-3.jpg
Old Mar 9, 2010 | 06:18 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
more..
Old Mar 9, 2010 | 06:23 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 97 SS rear end
the bolt pattern is identical..
you can install C clip eliminators.. I converted a 4th gen into my 3rd.. I machined the flange down on my axles allowing the axle to retain 3rd Gen width.. I have 91 & up disk
brakes. I modified the 9 bolt caliper bracket to diff flange to fit the 10 bolt..
you have to cut your diff as per mosher directions.. this leaves a perfect channel for a o-ring to seal against the press fit bearings on your axle
just a option!,,,,
Old Mar 9, 2010 | 06:24 PM
88gta3508's Avatar
Engine: 231 / 383
Re: 97 SS rear end
just a option!,,,, parts are very hard to find for the 9 bolt.. and have a high price tag..
Old Mar 9, 2010 | 06:25 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Re: 97 SS rear end
maybe I shouldn't have used the words "stick out". Some people may like how that looks.. it's all just opinion, I'm just not a fan of it. To each his own.
Mark.
Old Mar 9, 2010 | 06:31 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
Wow nice work!
I am not sure if I'd want to try and pull something like that off.
Old Mar 10, 2010 | 07:08 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Re: 97 SS rear end
Can anyone give me any info on the above pics I posted?
Old Mar 10, 2010 | 07:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 97 SS rear end
https://www.thirdgen.org/forums/tran...pair-info.html
JamesC
Old Mar 10, 2010 | 08:16 AM
88gta3508's Avatar
Engine: 231 / 383
Re: 97 SS rear end
it's hard to tell from your pics... look inside the carrier.. will see a cone that locks to engage POSI
put the carrier and axles in your diff... turn the yoke.. if the axles turn opposite directions it's a open carrier...
if both axles turn the same direction you have a Limited slip = POSI diff
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
