2 diff bolt patterns for 5spd fly wheel?
Old Mar 10, 2010 | 06:10 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
so i just got the 700r4 out of my 84 Z/28. a while back i picked up a complete 5 spd set up from a 87 RS. to my surprise the bolt pattern on my crank doesn't match the pattern on the 87 5spd trans. also does an auto crank differ from a manual car crank? it doesn't look like my pilot bearing is going to fit. do autos and manuals use the same drive shaft? thanks for the help
Old Mar 10, 2010 | 06:29 PM
Stephen's Avatar
Car: 87 GTA
Re: 2 diff bolt patterns for 5spd fly wheel?
Sounds like the replacement you got, is from a V6 car.
Old Mar 10, 2010 | 06:30 PM
Drew's Avatar
The crank is the same, the driveshaft is the same. The flywheel is different because 84 is a two piece rear main seal, and 87 is a 1 piece rear main seal.
Edit: To clarify, Auto - 5spd the crank and driveshaft is the same. The crank 84 - 87 is different because 86-up have a one piece rear main seal.
Old Mar 10, 2010 | 06:37 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Drew is the man... as usual, he is absolutely right.
I wish I had a 2-pc main flywheel for ya... but if you want to get rid of the one you have, I could use it, as I am about to do the exact same swap on my 88 GTA and I don't have a flywheel yet.
Old Mar 10, 2010 | 07:03 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
so it seems my options are find the 2pc rm fly wheel or install a 1pc rm motor? i wish i knew this before i pulled the auto!
Old Mar 10, 2010 | 09:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Find a flywheel from an '82-85 F-car with a V8. Problem solved.
Old Mar 10, 2010 | 10:39 PM
Drew's Avatar
Just buy one from the parts store. A used flywheel is probably going to need to be turned anyway, and how many times has it already been turned? Further ahead to buy a new one and get it over with. Subtract the resurface charge, and the value really starts to stand out.
Old Mar 11, 2010 | 04:46 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Ya know, Drew... the very same thing had occurred to me. I think the flywheel in question is around $100 at Advance.
If you buy a used one, it will cost $25 to $35 to resurface it, and if you pay $30 for it, you are paying about $50 to $65 for a used part... one that may have hot spots and also may have been machined too many times.
Add to that -- if you buy it out of state, you'll pay shipping charges, too. And flywheels ain't light. Plus if the guy at Advance gives you the wrong flywheel, you can return it easily.
Old Mar 11, 2010 | 04:01 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
summit racing has one for 74.95 ill go tht route for now i only drive the car 500-600 miles a year due to where i live
Old Mar 12, 2010 | 11:25 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Drew!!!
I thought that the crank was actually different, due to the different flange, having a 3 inch bolt patteren, as opposed to a 3 5/8 bolt pattern!!! This was all because of the rear main seal being changed from two to one piece!!
The cranks can be interchanged, but at this point, I can't remember the specifics, about doing that!!
Old Mar 12, 2010 | 11:30 PM
Hello S10GUY!!
The auto and manual cranks should only differ in the fact that the auto crank shouldn't have a pilot bearing, as it's not required, whereas the manual crank would!!!
Old Mar 14, 2010 | 12:06 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
my auto car has pilot provisions and i bougt an 82-85 oe wheel to get me by for this year until i install the 1 piece 355 next year
1992 Trans Am
May 10, 2023 07:19 PM
draco
Oct 4, 2015 09:25 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
milk
Aug 10, 2015 06:26 PM
