B&M ATF
Old Mar 15, 2010 | 01:44 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
B&M ATF
i don't know if this is the right place to post this or not, but if not let me know please. thanks. Has anyone ever tried using the B&M ATF? i have a B&M shifter in my auto, it came with the car when i got it. i found this B&M trans fluid at auto zone, and drained all the old stuff and filled it with this. is it safe? The guy at autozone said it should be safe...he got kind of excited and said he never saw it before but if he had a B&M he would deffinitely use it
Old Mar 15, 2010 | 01:59 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: B&M ATF
WELLLLLLLLLLLLLLLLLLLLLLLLLLLL!!!! depending on what type of maintenance the previous owner kept up will determine if you just created a large repair bill.... some people say it's a myth while others (ME) .. say it ain't no myth, it's fact in my book.... older transmissions for some reason, if they are not kept up on regular fluid changes have an allergic reaction to new fluid, why? Well as far as I have read, new fluid carries with it fresh detergent agents which are utilized by the transmission to keep the transmission lubricated and clean... all this stuff all of sudden gets cleaned up and leaves you with a boat anchor for a transmission...
If you had a recently built tranny then you should be fine... ... I have less than 10K miles on my tranny and will most likely begin the transition to Royal Purple... better heat transfer or something like that... ... It's midnight here, what else you expect
Old Mar 15, 2010 | 02:03 AM
Engine: 305 v8
Re: B&M ATF
so, what would be symptoms of this happening lol. i think this might have happened to me i guess i should have asked before i just did it.
Old Mar 15, 2010 | 02:21 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: B&M ATF
tranny will begin to slip, engine will rev really high... shift points will be off... some people (off site) have sworn than changing out their fluid to regular fluid fixed their slipping or non engaging problem, but hmmm...
Old Mar 15, 2010 | 02:47 AM
Engine: 305 v8
Re: B&M ATF
well...i don't think its slipping..but sometimes when i shift, it takes a minute to actually do the SHIFTING part lol...the engine doesnt really rev high..unless you mean my rpm's are higher than normal but I'm going slower than i should be for that particular RPM. I have noticed that. besides that i just have a loss of power. (big time) but i have plenty of other posts about that i guess.
Old Mar 15, 2010 | 03:05 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: B&M ATF
the revving part, I mean you're at a stop then step on the gas and the car barely moves, eventually it catches and shifts, the RPMs drop down ... may want to take it to a transmission shop, they typically don't charge for a check up... at least the ones I've dealt with here ...
Old Mar 15, 2010 | 03:24 AM
Engine: 305 v8
Re: B&M ATF
well..its sort of always done that since i got it, but only in first gear. i thought it was just the way the shifter worked. but, a free check up sounds great. no harm there...unless i find out my transmission is bad.but either way free is a good price to pay to find out. ill check into that tomorrow since i'm off. thanks for all your help so far.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
92GTA
Jan 23, 2005 08:35 AM
viperwsu
Feb 22, 2003 09:36 AM
KeithO
Jun 26, 2002 05:48 AM
