Pro 5.0 shifter install
Old Mar 20, 2010 | 07:46 AM
91black5spd's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 5 speed Manual
I am reinstalling my pro 5.0 shifter in a 1991 T5. I lost my install papers that had the torque specs and install instructions. Does anyone have these or know where I can find a pdf for them
Old Mar 20, 2010 | 10:04 AM
Drew's Avatar
Re: Pro 5.0 shifter install
You need instructions to install a shifter? If you absolutely need instructions, contact Pro 5.0. Otherwise, it's an extremely easy install. Just don't overtighten the bolts into the transmission, the case is aluminum and it will strip if you're not carefull. Once it's on, put the shifter into 3rd gear and push it all the way forward, adjust the front stop till it touches the shift lever, then snug the locknut. Do the same in 4th gear.
That's it. Simple.
Old Mar 21, 2010 | 03:26 AM
Pat Hall's Avatar
Yeah, you should only torque the bolts to about 20 ft. lbs. It's also a good idea to degrease the mounting flange of the trans with brake parts cleaner, then put a thin bead of Loctite 518 type sealer on there before you bolt it down. A lot of guys just use RTV, which works OK, but Loctite 518 is the best stuff to use. Then just adjust your shift stops the way Drew said.
Old Mar 21, 2010 | 07:19 AM
Engine: 305 TBI
That's it. Simple.
I know its easy to do, I installed it about 4 years ago then switched back to stock. The reason I wanted the instructions is for the torque specs so I dont overtighten.
Also, I never cut the inner boot when i did it before and this time I think I will so it shifts better. The instructions had a template for that with the size of the circle to cut.
Old Apr 16, 2011 | 10:05 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
my shifter hits my shifter plate in 1st 3rd and 5th. why? also i had to flip my handle around in order to work. has anyone else had these problems?
Old Apr 20, 2011 | 11:35 PM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
fixed my problem. put it in a press and bent the shifter about 25* know shifts flawlessly.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
