MY 700r4 Problem
Old Apr 20, 2011 | 09:32 PM
lethaldomestics's Avatar
MY 700r4 Problem
This is my first post
i am a proud owner of a 1987 firebird trans am w/ 305 TPI and a 700r4 trans.
The problem i am having? FROM A DEAD STOP if i hit the gas the car goes like hell but wont shift until i let off the gas. In other words i could send the rpms through the roof. It also stalls if i take a turn too fast. any help would be great i am new to these cars and need help. thank you
Old Apr 21, 2011 | 02:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: MY 700r4 Problem
Have you adjusted the TV cable properly?
What happens when you are cruising at say 35mph, and the get on it (not quite WOT) - it should downshift, but as the speed increases will it upshift again?
Like - if cruising in 4th, you gun it, drops to 3rd, accellerates, then does it shift back up into 4th without issue?
What happens when you are acellerating pretty rapidly (again, not nailed WOT, but just rapidly) - does it shift into gears then as it should?
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
