going to a th-350
Old Mar 22, 2010 | 03:30 PM
bwebb's Avatar
going to a th-350
my th350 has the short tail shaft so would it be worth my while to rig the original 700r4 cross member or buy a aftermarket one.
Old Mar 26, 2010 | 11:07 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: going to a th-350
Also with a short tail, 6", you will need a 3 inch longer drive shaft. You can re-use your existing driveshaft if you use a long tail, 9", TH350.
Old Mar 26, 2010 | 12:06 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
If you definetely going to use a short tail T-350 and could afford to buy the new torque arm/crossmember I highly reccomend it. I tried to rig the aftermarket brackets up and eventually got fusterated and quit. I even bought both Hurst and B+M kits.
I bought the Spohn X-member + T/A and couldn't be happier with it.
TexasMaro
Sep 15, 2015 06:50 PM
Dan83
Jul 19, 2003 03:30 PM
Changa2
Mar 31, 2002 03:09 PM
88 Formula
Mar 15, 2002 07:31 PM
chicksL69
Nov 8, 2000 06:24 AM
