4 speed manual swap to th350
Does anybody know what the 4 speed manual is. i recently swapped my v6 with 4 speed manual..for 350 with the th350 tranny can anybody tell me what is needed for this swap i cant find any threads on this thank you
Re: 4 speed manual swap to th350
Check out the engine swap forum and read up one some V6 to V8 swaps
The early 3rd gen 4 speeds were nothing to write home about. A few top trim level cars got the Super T-10, but those were uncommon. Most were about as strong as the old saginaws of years past. Nothing to write home about
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
As stated above, you need a different driveshaft.
This is the one I have. You have to find someone like Spohn that makes a driveshaft for a 82-92 F-body with a short tail TH350 or measure and have a drivline shop make one for you.
http://www.spohn.net/shop/1982-1992-...hort-Tail.html
From what I understand, the driveshaft from a 82 and I think 83 f-body with a factory 200-r4 will also fit but you might be searching for a while to find one, so I personally wouldnt even waste my time. I also wouldnt want to deal with a nearly 30 year old driveshaft.
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
The drive line doesn't need to go all the way in. It should have a nice seal though. Just make sure you can move it up and down. I believe the drive line still goes in like 3" in.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
