700R4 - Transplanting Internals
Old Apr 18, 2010 | 07:08 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Is it possible to transplant the internal components of a 700R4 that came off a 2.8L V6 into the case of another 700R4 that was behind a 5.0L V8?
The V8 transmission was apparently underwater (along with the '82 Camaro) but I have 2 good V6 transmissions.
Cheers!
Old Apr 18, 2010 | 07:57 PM
Pro Built Automatics's Avatar
Re: 700R4 - Transplanting Internals
First what years are we talking about? Is this the 2.8L, the small case bolt pattern? If it is then the input drum will be different.
Old Apr 19, 2010 | 01:27 AM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Yes. My good transmissions are all 2.8L V6 units. Apart from the input drum (hopefully mine is okay), are the other components interchangeable?
Old Apr 19, 2010 | 09:59 AM
Yes, but what years are these?!!!
Old Apr 20, 2010 | 04:51 AM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
I believe the V8 transmission (case) is an '82. One of the V6 transmissions is probably an '84. They are at the farm about 50 miles north and I'm too busy flying to visit them. I will post again once I have definite information on these units.
One of the V6 transmissions is in my laundry area. It came off an S-10. I'll try to determine it's vintage when it gets light outside.
Thank you very much for your interest in my problem.
Cheers!
Old Apr 20, 2010 | 05:23 AM
The internals from 1982 - 1986 are pretty much the same. You will have to check out the condition closely, when it is disassembled.
Old Apr 20, 2010 | 10:27 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Thanks for that info. Assuming the V8 transmission's input drum is toast, can a new or reconditioned one be bought easily? Are there any upgrades that "should" be done while the transmission is apart?
Old Apr 22, 2010 | 01:12 AM
Yes, but to much to cover here. Call me at 909 795-1876 anytime in the afternoon or evening. Dana
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
