700R4 question
Old Apr 21, 2010 | 03:07 PM
afbadger's Avatar
Car: 1989 Trans AM GTA
Engine: 5.7 Stock
700R4 question
Gents, I put a 92 camaro tranny in my 89 GTA, I put a new torque converter in it as well. Is there adjustments that need to be made because it shifts pretty hard into second when its cold, and it doesnt have a good launch from a stop anymore, I cant spin'em and it shifts too quickly to the next gear. Is there an easy way to adjust this or am I stuck with this performance?
Old Apr 21, 2010 | 05:46 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: 700R4 question
Search the board for TV cable adjustment. It's very simple to do. If your trans is shifting too quickly it can be very detrimental to the internals.
Old Apr 21, 2010 | 05:50 PM
afbadger's Avatar
Engine: 5.7 Stock
Re: 700R4 question
I heard of the TV cable, is it hard to adjust? Do I need any special equip? Or should I just take it to a GM dealer and have'em do it? Would this cause all the problems I'm having? It would be nice. Thanks for your input.
Old Apr 21, 2010 | 06:01 PM
1986v6's Avatar
Car: 1986 camaro v6
Engine: soon to be 305
Axle/Gears: someone please tell me
Re: 700R4 question
the tv cable for a 700r4 is extremely easy to adjust, you need no tools and only about five minutes to do it. The cable itself attaches to your throttle on the motor, you should be able to find it by following the cable from your tranny to the throttle on your tbi/carb, on this cable there is a silver button usually d shaped from my experience, press that button in and hold it while sliding the housing of the cable towards it from the throttle side once you have bottomed it out then release the button and then you will need to manually open your throttle all the way up by turning it on your carb/tpi by hand while doing this you should here a series ofclicks then release the throttle, also in my experience dont try using the pedal to open up the throttle it doesnt open all the way on some vehichles alsways do it by hand on the tpi/carb
I hope this helps
Old Apr 21, 2010 | 06:02 PM
Re: 700R4 question
https://www.thirdgen.org/detent
The engine in the picture is a V6. The principle is exactly the same on the V8s.
Old Apr 21, 2010 | 06:09 PM
afbadger's Avatar
Engine: 5.7 Stock
Re: 700R4 question
Thanks Gents, sounds pretty easy. So does this setting, pushing it all way flush, reset it or something or what? another thing, is having a 92 camaro tranny messing it up? the camaro had a 305 in it, i got a 350. does that have something to do with it?
Old Apr 21, 2010 | 06:15 PM
Re: 700R4 question
Yes, that sets the shift points in the transmission by adjusting the cable. You'll push it all the way flush and manually move your throttle body to wide open and back one time, during this time you'll hear a clicking or ratcheting noise. That's the cable adjusting.
The transmission coming from a 305 should not be an issue, provided you are using the same detent cable that was already in your car. GM offers two different detent cables for those cars, one for a 305/350 and one specifically for the 350. I had an issue a couple years back with being unable to adjust my shift points properly, and it turned out I had the incorrect detent cable for my application.
Old Apr 21, 2010 | 06:21 PM
afbadger's Avatar
Engine: 5.7 Stock
Re: 700R4 question
no, Its my original cable. I'll give it a try tommorrow and see if that fixes it. I miss lighting those tires up and kickin sideways. Now it just studders throught the gears,its weird.
Old Apr 21, 2010 | 09:51 PM
1986v6's Avatar
Car: 1986 camaro v6
Re: 700R4 question
I had a similar problem on my van, I ended up having to change the tv cable because a few of the strands had broken inside the cable and I couldnt get it set right, only cost me about 40 bucks and it made a huge difference
Old Apr 22, 2010 | 01:25 PM
afbadger's Avatar
Engine: 5.7 Stock
Re: 700R4 question
Well, I adjusted the TV cable and that fixed my problem! Thanks guys, now my car doesnt shift like its falling apart!
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
