no 3rd or od after shift kit
Old Apr 23, 2010 | 09:53 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
ok. I got a shift kit and put it in yesterday and had no reverse and shifted like crap..when I pulled the pan the pressure valve snap ring and booster was in the pan..so I put it back in and it fixed that issue..took it down the street and it worked great.. let it sit for 30mins and went to go to the parts store and I lost 3rd and od... what would make it just lose 3rd and od??? It just revs and dont go anywhere..you can hear it shift but its just dead in them gears..1rst and 2nd work great...did I put something in wrong?? why would it just quit???Confused..someone help....I have it pulled apart now and ripped the valebody gasket when it came down..I looked over everything and check ***** are correct..some one please help...
Old Apr 24, 2010 | 03:18 PM
Car: 88gta
Engine: 357
Re: no 3rd or od after shift kit
anybody???? It starts moving again around 3500-4000 in drive but thats it..
Old Apr 25, 2010 | 08:08 PM
Car: 88gta
Engine: 357
come on anyone...I have taken it apart 5 times now, put a differant valve body in it and its still the same thing..no 3rd and in od it starts moving around 3500-4000...what could have happened from putting in a shift kit???all check ***** are where they are supposed to be...and it was fine before the shift kit..someone please help...dont have the extra money to get a new trans...
Old Apr 26, 2010 | 02:03 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
What brand kit did you use? I installed a TRANSGO, works great, They have a nice install video to download, and they have a great staff to help you with any questions. Maybe go to their web and download the install video and go thru and check for any mistakes.
Old Apr 26, 2010 | 06:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
How much magic dust was in the pan after you lost 3rd and 4th? I doubt it's a problem with just the shift kit now.
Old Apr 26, 2010 | 07:00 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I have no OD after my shift kit and was told by a transmission guy that it has an internal leak.
Old Apr 26, 2010 | 07:34 AM
Car: 88gta
Engine: 357
it was a b&m... and there was some magic dust as you call it in the pan...so I should start looking for a new tranny huh???
Old May 4, 2010 | 09:45 PM
Car: 88gta
Engine: 357
well after talking to a transmission guy.. he told me to check the 3-4 acc piston and bore and check for a torn seal or scratches.. and to check the govener.. I did just that.. sanded and made sure no scratches put a new piston seal and checked the govener... and still nothing....I am so lost here....I have done these shift kits before and never had any problems...I just dont get what could have happened
Old May 5, 2010 | 06:53 AM
92 Camaro's Avatar
how old is the transmission? i had a pressure test done so maybe that's what you should do.
Old May 5, 2010 | 07:00 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I'm guessing you are just the victim of bad luck/timing. Sounds like you smoked the 3-4 clutchpack. That is the typical way a 700r4 dies of old age.
Old May 6, 2010 | 07:58 PM
Car: 88gta
Engine: 357
I am going to give it a pressure check..but I guess its the only thing I can do..I guess its time to get one rebuilt..any idea how much that should cost?
Old May 6, 2010 | 08:52 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
the increased pressure from the kit may have blown the 3-4 piston lip seals.
Old May 6, 2010 | 09:47 PM
Car: 88gta
Engine: 357
3-4 piston,on the accumulator??? I just changed it.. it was good, but still no 3rd or 4th
Old May 7, 2010 | 12:35 AM
no. the lip seals inside the input housing. the piston that mechanically engages the clutch pack. was there any black material in the pan? there is also a check ball in the case, under the valve body that can leak and cause this problem. (it doesn't come out when doing a shift kit)
Old May 7, 2010 | 10:36 AM
Car: 88gta
Engine: 357
yes there was black material in the pan..
Old May 7, 2010 | 01:55 PM
the black material is clutch material. time for a rebuild.
Old May 10, 2010 | 12:04 PM
Car: 88gta
Engine: 357
well damn... I have a tranny guy thats gonna go through the other one I have.. what should I get before he does it... vette servo,boost valve, trans go kit..
Old May 10, 2010 | 04:28 PM
the sun gear shell is a very weak part of the tranny. get a heavy duty one. make sure the kit comes with high energy 3-4 clutches. you can also remove the 3-4 boost springs for a firmer 2-3 shift.
Old May 10, 2010 | 05:10 PM
Car: 88gta
Engine: 357
sun gear shell?? where is that?? the tranny case?? where is the cheapest place to get this at?? Thanks for all your help..
Old May 10, 2010 | 05:21 PM
i use TPU here in town. if i remember correctly it was $80. they may have online ordering or you can ask Dana. yes its inside the case.
Old May 10, 2010 | 08:15 PM
Car: 88gta
Engine: 357
dana?? is he the guy from pro built?
Old May 10, 2010 | 09:02 PM
yes. if you call him now he should answer. he is in cali. 909-795-1876
Old May 13, 2010 | 07:16 PM
Car: 88gta
Engine: 357
well I dropped off the spare tranny to have to get checked out.If all is well I am going to order the sun shell,the vette servo,the overhaul kit w/ upgrades,and the raybestos modified 3-4 clutch pack...and then my tci 300 stall convertor....and then hopefully I can get my 355 in there...
Old May 13, 2010 | 09:06 PM
89z28iroc-z's Avatar
Car: 89 z28 iroc-z
Engine: 355 compcam vortec heads
Transmission: th350 10'' dayco 2800-3200 stall
Axle/Gears: 10 bolt with 2:73 upgrading soon
3-4 just went out on 700r4 trans. i put a new trans filter and new trans fluid in it when i rebuilt the motor in 08. 3 gear was slipping a little when it got hot but it still shifted. now it just revs up in 3-4. what should i do get the old one rebuilt or get a new one? my buddy keeps telling me to put a th350 in it but i like the over drive. any suggestion would be nice.
Old May 14, 2010 | 09:36 AM
Car: 88gta
Engine: 357
thats exactly what mine did...Mine is at the tranny shop now...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
