700r4 shifting way late
Old Apr 24, 2010 | 10:53 AM
fiero377ci's Avatar
Car: 85 iroc
Engine: 355 tpi
Transmission: 700
my camaro with a 355, small crane, 9.5:1 etc etc. has a 700 behind it that i dont know the history of. it shifts hard into 2nd but kind of floats into 3rd and od. the real problem is that at the strip it just wants to keep revving to 5500 before shifting in each gear. it has 3.73 rears. trying to shift manually makes no difference i bump it to the next gear but it wont shift until it wants to. and ideas? vette servo?
Old Apr 24, 2010 | 02:56 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: 700r4 shifting way late
Did you adjust the detent cable?
Old Apr 26, 2010 | 04:47 AM
crackitoff's Avatar
Engine: Shafiroff 434
Transmission: Jake's Performance Stage 4 TH400
Axle/Gears: Strange S60/spool w/ 3.73's
mine had the same problem last year. ended up being the 3-4 clutch packs starting to wear out. had the trans rebuilt and problem fixed.
Old Apr 27, 2010 | 04:55 AM
jedidethfreak's Avatar
Lucas Tranny Fix might solve it. It did for me with the same issue. Otherwise, it may be time for a rebuild.
Old Apr 27, 2010 | 05:46 AM
fiero377ci's Avatar
Car: 85 iroc
Engine: 355 tpi
Transmission: 700
well the detent is adjusted correct. it is a pint low on the stick, i highly doubt it would affect anything. it shifts good but wants to rev out to 3500 b4 shifting into 3rd and 5500 under full throttle. they was nothing abnormal last time i changed the tranny fluid 10k miles ago
Old Apr 27, 2010 | 06:31 AM
Fuzzman17's Avatar
Car: 92RS
Engine: 305 TBI
Transmission: 700
It could be your TV spring. go here www.tvmadeez.com and you might find some helpful info.
Good luck
Humm Looks like the page timed out when I tried to load it. 2nd time in as many days that I have had that problem with web pages, strange.
Old Apr 28, 2010 | 10:48 PM
Pro Built Automatics's Avatar
This 700R4 sounds like it has the 5,500 rpm governor in it. This governor "will not" allow you to shift at a "earlier" rpm at WOT. DO NOT adjust the TV cable to make it shift earlier, as this will destroy the transmission. You can change to a V8 governor, and that will allow you to shift earlier.
Old May 1, 2010 | 10:16 AM
fiero377ci's Avatar
Car: 85 iroc
Engine: 355 tpi
Transmission: 700
well according to the lady i bought it from who claimed to be the second owner it is the original trans, just rebuilt. i guess who knows what was put in it. ran last night and it hit 5800 b4 it would shift into 2nd and 5500 into 3rd but still managed a 13.9
junior419
Apr 7, 2025 11:35 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
TheTraut88
Sep 7, 2015 05:22 PM
