Rebuild next week (700R4)
Old Apr 29, 2010 | 10:12 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Am removing the tranny, and taking it to have it rebuilt....Anything special, I should have done to it while it is out, and being worked on...I have a Corvette servo in it, and a B and M shiftkit...The converter is making noise with 17400 miles on the clock, so am going back with a tork master 2400...Any suggestions??? Thanks, Tom
Old Apr 30, 2010 | 01:10 PM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: Rebuild next week (700R4)
talk to dana from http://www.700r4l60e.com/ he can set you up with everything you need and have the trans shop install it
Old Apr 30, 2010 | 05:37 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
I have a good tranny guy, he has been running, and building Camaros for years...I think his current 3rd gen runs 8's in the 1/4...Anyway, I was curious about what you guys consider "have to have parts"...Thanks, Tom
Old Apr 30, 2010 | 11:05 PM
Pro Built Automatics's Avatar
Just because he runs 8's, doesn't mean he knows how to build a 700R4 right. See how successful his 700R4's are doing.
Old Apr 30, 2010 | 11:11 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
get a heavy duty sun gear shell.
Old Apr 30, 2010 | 11:20 PM
glock's Avatar
Car: 1989 gta
thats why i said talk to dana from pro built he is like a guru of the 700r4 ...he will tell u what you need
Old May 1, 2010 | 07:47 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
You of course are right, but he has had his tranny shop for about 35 years...He built my last one in the 90's, and it outlasted the motor..lol..And thanks for the replys guys......Will check into the guru.....Tom
Old May 3, 2010 | 10:22 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I second calling Dana at Pro-Built Automatics! He knows his 700r4s! He's doing my kit now. He'll ask you tones of questions in order to customize the kit just for you.
Old May 3, 2010 | 10:54 PM
90BlackGTA's Avatar
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
I'm also having my 700r4 rebuilt soon and while I would love to go with a kit from Dana at pro-built my main reason for not doing so is because I couldn't risk spending the money and not having any warranty especially being only 21 years old and limited money. No shop it seems will issue a warranty unless you use their parts supplier so having them rebuild my transmission with Dana's kit is most likely out of the question. I think if you ask other car owners and search around you can find someone or a reliable transmission shop in your city. The place i'm going I talked to about what I wanted and what my future plans were with the car and they were very helpful and willing to answer any questions. They assured me they only use the highest quality of parts for a rebuild including things like corvette servo,etc. So we'll see how it goes. If I was mechanically inclined then this would probably be a different situation but I still have lots to learn :P
Old May 5, 2010 | 06:44 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I would defer to your trans builder only for parts selection. He probably has done hundreds of them, and can make the best choices for you.
Old May 6, 2010 | 02:19 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
He has..His name is Donnie Dick, Galveston County...I am just worried that I bought too much converter for my motor , it is ab&m 2400 stall.. It does have lockup, but with a 3.23 I think it may be more than I need..I hope not cuz this my daily driver..I guess as long as it locks up in Od it will ok for the time being..17400+ on the clock, and the tranny is still good, but with a stall I was worried....Do you guys think 2400 stall (flash is to much with 3.23 gears is too much?????Doing the tranny, fuel pump upgrade, UNI panhard, and lower control arks, along with another set of headers at the same time....Hope it gets me 3 tenths in the 1/4 mile...Suggestions?? Thanks, Tom
BTW got rear end girdle, and a new seals, rear main, pinion.l..Open to any suggestions............................................
Old May 6, 2010 | 03:39 PM
The 2,400 rpm stall is fine. It being a B&M is not. If your builder is recommending a B&M TC.... find another builder.
Old May 7, 2010 | 08:15 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Truer words have not been spoken.
Old May 7, 2010 | 04:12 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
My builder did not recommend it, he actually said a vette converter would work the best for my mild build..To late already have it now...B&M shiftkit, and Shifter too...This has become a major job now....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
earlpote
Sep 12, 2015 11:55 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
