92 t-5 into 86 iroc auto
Old May 6, 2010 | 11:07 PM
johnson7454's Avatar
Whats parts do i need from the 92 to make the swap into my 86 iroc and what problems, if any will i run into? Dont know alot about the interchangeable years and stuff.
Old May 6, 2010 | 11:29 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 92 t-5 into 86 iroc auto
you will need the T5, clutch pedal assm. master Cyl
re- work your neutral safety switch. purchase a real shifter, install a roller pilot bearing,
get a new through out bearing ( DO NOT buy this from Auto ZONE it's half plastic )
new clutch, fly wheel.. measure and cut your floor.. get a poly trans mount same as the AUTO.. cross member is the same you will need the bracket for the master Cyl
and a manual center console.... fill the T5 up with trans fluid 3 QTs or so
Old May 7, 2010 | 12:17 AM
explain the neutral switch? real shifter? roller pilot bearing? is this because its coming from a 92 instead of a 85-88
Old May 7, 2010 | 12:28 AM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
I'm assuming that you are going from 700r4 to T5, years are not important. By "real shifter" he mean's "not stock" Neutral switch is the switch that allows you to start your car, park or neutral. That needs to be bypassed so you can start at anytime, or wired into the clutch switch. The roller pilot bearing is what the snout of the input shaft rides on. It's installed into the back of your crank. There is a solid brass type and a roller type. I myself prefer the roller too.
Old May 7, 2010 | 12:42 AM
o. i have only messed with the solid brass ones, so the roller part threw me off. Do i need the whole console or just the shifter plate.
Old May 7, 2010 | 12:46 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You just need the shifter plate. Good luck on that one, they seem to be difficult to find in decent shape.
Vice04's Avatar
Car: 84 Monte
Shifter plate, could make due with the auto one with a dremel, some courage, and ingenuity though
Old May 7, 2010 | 12:49 AM
Vice04's Avatar
Car: 84 Monte
lol, I do have one, but didn't want to let go of the console parting out the car. My best bet would be Fbodymotorsports.com, Hawks Third Gen or Year One maybe
Old May 7, 2010 | 07:48 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Not sure if it was clear above but the flywheel from the 92 won't work. The swap isn't too bad of a project and can be done in a weekend. One tip is to make a cardboard pattern of the firewall from the donor car using the steering console as a reference point. This makes cutting the firewall a simple process for the location of the clutch cylinder.
MantyZ28
Oct 16, 2015 09:12 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
