how long will a t5 last in back of a 350tpi
Old May 4, 2010 | 01:54 AM
tommyz24's Avatar
hi guys , i have an 87 with no motor but with a the 5 speed tranny still there. I really just want to drive this thing this summer without hurting my wallet. I've found a few 350 tpi around here at decent prices . Just wondering if i can drop the 350 in and drive " a little fun" but mostly cruising . Or will it crap out on me after a few hard shifts?? thanks for the help.
Old May 4, 2010 | 02:42 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
Re: how long will a t5 last in back of a 350tpi
ive been lucky with mine, so far i have 2 years on mine with 542hp at the flywheel and i don't tiptoe with it either. it should be fine so long as you dont drop the clutch too hard too often, but i think that goes for just about any engine in front of it.
Old May 4, 2010 | 02:44 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Double check bearing play and move the tq arm mount to the xmember and you'll last a LOT longer.
Old May 4, 2010 | 04:35 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
being an 87 i'd assume it's a world-class T5?
Old May 4, 2010 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, 88 was the first year for the WC.
https://www.thirdgen.org/forums/tran...5-hold-up.html
JamesC
Old May 4, 2010 | 08:08 AM
ownor's Avatar
Engine: LS1 / L03
haha, in that case imho it might hold up for some while behind an L98, depending on your driving habits.. but probably not too long if you're planning to actually use the extra power of that L98 compared to the powerband of an LG4 or similar. my non-WC T5 behind the L69 has become a bit tired as well at only 90kmls.
James posted a link of a very recent thread about the same question, so you better use the search next time or just use your eyes, it's only a couple of threads below yours
Old May 4, 2010 | 08:13 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
My first T-5 lasted about 300 miles before I did a 1-2 gear burnout behind my 383...I had it first behind my 350 and it did fine but it was a very very mild 350.
Old May 4, 2010 | 08:26 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
My guess with you asking that question, it will not last long considering some of your statements
RS Reaper
Oct 17, 2018 07:52 PM
David Frans
Oct 31, 2015 08:12 PM
Marc Brown
Sep 28, 2015 01:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
RedLeader289
Sep 23, 2015 06:50 AM
