700r4 problem
Old May 5, 2010 | 07:38 AM
Allan Dollaway's Avatar
Car: 1988 trans am
Engine: 305tpi
700r4 problem
Hey guys,86 305 TA with stock 700r4.Went to leave this morning and it will not shift out of first.Wsa fine last night,and it seemed to idle much higher this morning.Checked tv cable at TB.end,is hooked up,fluid ok,didnt see any broken vac lines.Any ideas off hand Thanks Allan
Old May 5, 2010 | 07:42 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700r4 problem
The governor may be sticking, or the gear may be "apple cored". Pop off the rusty 2 1/2 inch diameter cover on the drivers side of the transmissin to remove and inspect.
Old May 5, 2010 | 11:14 AM
Car: 1988 trans am
Engine: 305tpi
Re: 700r4 problem
Thanks! will check after work.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
