4th gen rear swap question
Old May 4, 2010 | 11:53 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
What is that plug on the 4th gen rear that has a tiny magnet inside and plugs into the car via a blue plug? The magnet/sensor side goes into a 1" approx. diameter hole in the top of the gear housing.
I wonder if that plugs into my third gen or if it was some new feature on the 4th gens. I haven't pulled the rear out of my 86 yet, so I don't know if it has that on it or not.
Thanks guys.
Old May 4, 2010 | 11:59 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 4th gen rear swap question
ABS sensor.
You won't use it so just leave it in the diff.
Old May 4, 2010 | 03:26 PM
russlavoie's Avatar
whats the the advantage of putting a 4th gen rear end in compared to a third gen rear with the same gears?
Old May 4, 2010 | 03:45 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
wider (for 4th gen wheels), disk brakes as opposed to drums. IIRC they're both 7.5" 10 bolts.
Old May 4, 2010 | 04:22 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Posi and disk brakes, as well as running 4th gen or vette wheels.
Old May 4, 2010 | 06:01 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Also 28 spline axles, which some third gens don't have. It's a bit stronger.
Old May 4, 2010 | 06:30 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
but the same weak point C clips
I had to machine my 4th Gen axles.. to 3rd Gen width. after I installed my Moser C clip eliminator.. to retain my 1LE brakes
Old May 4, 2010 | 06:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A late 89 to 92 rear-disc car would have pretty much the same rear end as a 93-97: 7.6, 28-spline axles, an Auburn, and PBR calipers. So swapping either rear end into an 82-88 car with a 7.5 or 7.6, Gov-Loc and/or Auburn, with Delco-Moraine calipers would be an upgrade. The LS1 (98+) with its Zexel-Torsen and superior brakes would no doubt be the best choice for an 82-92 swap.
JamesC
Old May 4, 2010 | 07:15 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by JamesC
A late 89 to 92 rear-disc car would have pretty much the same rear end as a 93-97.....
JamesC
Yes & no James.....
Internally. not much difference.
Externally? Almost 4" wider (2" per side). That can have a real effect on wheel fitment.
Old May 4, 2010 | 08:37 PM
JamesC's Avatar
I assume that was a given.
JamesC
Old May 4, 2010 | 10:54 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I have read on here that the stock wheels fit fine with a 4th gen swap.
Old May 4, 2010 | 10:57 PM
Stephen's Avatar
Car: 87 GTA
16" rear offset wheels yes.
Front wheels offset will cause them to stick out, but only by about 1/4".
Stock 15" wheels will be out by almost another 1".
Old May 5, 2010 | 09:23 AM
Zepher's Avatar
Does this look funny or what?
This is a GTA rear wheel on my LS1 rear,
Old May 5, 2010 | 10:23 AM
Stephen's Avatar
Car: 87 GTA
In the first pic, I'd say that car needs an adjustable Panhard Bar. I bet the other side is under the fender.
On your car, I'd ask what size tires you have, because I know a local Camaro with stock wheels, stock 245s & a LT1 rear, which is a bit wider than the LS1 rear, yet his seems to be "in" more than yours (blue car on the right, next to my white GTA).
Yes, my 315s on 11" wheels, on my stock 9-bolt rear axle fit better, but I also have an adjustable panhard bar. Stock, the crosslaces sat further out on the drivers said than the passenger side. Still under the fender, but not centered. I had to get an adjustable panhard bar to center it up good, before putting the 11"s & 315s on.
Old May 5, 2010 | 10:34 AM
Zepher's Avatar
the green car was the same on both sides. they aren't factory wheels and had a slightly higher or lower offset.
My GTA wheels had the stock size 245/50/16 tires.
with 315's on correct offset wheels and LS1 rear,
Old May 5, 2010 | 11:03 AM
Stephen's Avatar
Car: 87 GTA
Define "correct offset". I still have the early 3rd gen aluminum drum spacers (thought I'd need them. i didn't, i just never bothered to pull them back out) so really, mine could go in another 4mm (about 1/4") under my 7"bs wheels.
Looks like your 315s fit under the fenders pretty good too.
Old May 5, 2010 | 11:51 AM
Zepher's Avatar
I meant to say stock LS1 offset wheels on my LS1 rear, even though the wheels are 1/2" wider than stock SS and WS6 wheels.
They are 17x9.5 wheels with sumitomo 315's (for some reason Sumitomos are skinnier than other 315's)
Old May 5, 2010 | 11:58 AM
Stephen's Avatar
Car: 87 GTA
Tell me about it.....
I had my 9" widened to 11", then got the Sumitomo 315. I coulda just put the 315s on the 9" wheels & saved me the custom widening cost!
Oh well.....Next time I'll get "real" 315s & need the 11" wheels.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
