need answers what will it take 2 get a turbo 350 in replace with out the 700r4
Old May 7, 2010 | 09:09 PM
jake1992jake's Avatar
Car: 1989 camaro rs
Engine: 406 chevy
Transmission: turbo 350
Axle/Gears: 3:73 posi
need answers what will it take 2 get a turbo 350 with out using a kit got pics of any homade ones crossmembers or modifiy 1
Old May 7, 2010 | 09:21 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: need answers what will it take 2 get a turbo 350 in replace with out the 700r4
I'm not sure what you mean here. If you want to use a TH350 then you'll need the hardware that goes with it to make it work in a 1982-1992 F-body car. The crossmember is available at many of the site sponsors. Or if you get lucky you can pull what you need out of a 1982 Trans Am or Camaro which used the TH350.
Old May 8, 2010 | 11:12 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I just posted this on another thread, but its the easiest way to do the swap. Its well worth the hundred bucks. http://www.summitracing.com/parts/BMM-30299/
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
92purpz28
Aug 11, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
