V-6 T-5 for V-8
Old May 23, 2010 | 12:48 AM
camaro88ukraine's Avatar
Car: Camaro 1988
Engine: 305, carb. 600cfm double pumper
V-6 T-5 for V-8
Hi. Can i install V8 into my 1988 V6 Camaro with T-5 Borg Warner manual transmission if i'll buy V8 T-5 bellhousing?
like this one
http://cgi.ebay.com/ebaymotors/82-83...item2307555780
or this
http://www.summitracing.com/parts/MC...n/?prefilter=0
thanx
Old May 23, 2010 | 05:34 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: V-6 T-5 for V-8
Guys have done that. You need to get a clutch disc that matches the splines on the V6 trans... I think the one from an S-10 works.
The V8 swap is the larger issue. It's best to find a donor car to get all the parts you will need... not sure how easy that will be for you in the Ukraine.
Old May 23, 2010 | 09:02 AM
Car: Camaro 1988
Re: V-6 T-5 for V-8
thank you. S-10 is hard to find here. 90-96 Chevy Caprice is much easier to find.
I want to buy new clutch kit from 1982 Camaro which was equipped with T-5 , throw out ECM and put carburator on this V8
Old May 23, 2010 | 07:21 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Re: V-6 T-5 for V-8
OK but the splines on a V6 T5 are coarser than on a V8. The V8 uses a 26-spline input shaft, and the V6 is 14.
If you buy a clutch from a V8 Camaro, it won't fit the input shaft on the transmission.
Old May 24, 2010 | 12:58 AM
Car: Camaro 1988
Re: V-6 T-5 for V-8
Hmm... So which clutch kit from which car i should buy?
4.3 5.0 S10 uses 10 spline input shaft
http://www.summitracing.com/parts/ZZZ-MU1877-1/
2.5 2.8 S10 uses 14 spline
http://www.summitracing.com/parts/RA...ER&prefilter=1
Old May 24, 2010 | 04:43 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Re: V-6 T-5 for V-8
Sorry... I knew I should have looked it up. The 10-spline is the one you want...
So go with the 4.3/5.0 S-10 disc. I am not sure if you can use the whole clutch kit, but I know that's the right disc.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
