name that sensor!!
Old May 23, 2010 | 12:57 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
name that sensor!!
hey everybody!
i bought a t-5 pedal assembly recently and there's one sensor that's stumping the hell out of me. I was told the pedals came off of a 1987 car. i know on the clutch pedal there's the cruise control and the neutral safety switches, and on the brake pedal there's the brake light switch, but right next to the brake light switch is a little black switch i have no idea is for. i don't have a sensor like that on my automatic pedals. enlighten me, guys!
P.S. sorry for the sideways view. not sure why it turned it around.
Old May 24, 2010 | 04:19 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: name that sensor!!
looks like the BTSI. Brake Transmission Shift Interlock. Doesn't let you shift without having your foot on the brake.
Old May 24, 2010 | 04:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Shift interlock? On a manual trans? Would be the first Ive heard of. I can research it for you if I had the wire colors that went to it. I would guess that its speed control defeat. From the
Old May 24, 2010 | 04:33 PM
1981LT1's Avatar
Engine: LT1; LT1
Hah! I need to pay more attention. I just looked at the wire colors. My bad.
Old May 24, 2010 | 04:37 PM
1981LT1's Avatar
Engine: LT1; LT1
looking at it again, I would think the ltblue/orange wires are your brakes and the circular thing looks like your cruise/vacuum deactivate. Are you asking what the two wire plug is for?
Old May 24, 2010 | 05:04 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Lol. Happens to me alot. Youre dead on too. That is a cruise vacuum defeat. Seen it before. The Gry and Gry/Wht wires are cruise defeat sw. Org and Blue are brake lights.
Old May 24, 2010 | 11:40 PM
GTAman's Avatar
thanks for the input, fellas! i don't know the wire colors for this sensor. heck i don't even know what it's for! lol my 1988 GTA has cruise control but doesn't have this simple black switch on the brake pedal. all it has is the cruise control cancel switch (the one with the electrical connector and the vacuum port for the hose).
Old May 26, 2010 | 09:22 PM
GTAman's Avatar
hello?
Old May 27, 2010 | 10:35 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Sorry for disappearing on you. Been busy at work. I belive that the black piece is the cruise control vacuum defeat switch. Its been a while since Ive worked on one like that. The switch with the gray wires is elec cruise defeat. It doesnt have a vac port does it? I dont remember that.
Old May 28, 2010 | 02:32 PM
GTAman's Avatar
it's ok. so there's two cruise control defeats on a clutch pedal assembly? there's a cruise control defeat switch with a vacuum port on the clutch pedal side (has two gray wires). it looks exactly like the cruise control switch that i have on my automatic brake pedal assembly. so a vac hose should go to the black sensor too?
Old May 29, 2010 | 01:43 AM
GTAman's Avatar
here's a close up
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
