Rear end
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
Rear end
so here is the deal. my 82 z28 has work done onto it, and i want to know if this is something else that was done before i got the car; the rear end is a 10 bolt with 3.45 gears. is that stock? if it is, what is the quality? thanks a lot.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear end
https://www.thirdgen.org/1982-chevy-camaro
10-Bolt FAQ for more info about gears, brakes, axles, etc:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Re: Rear end
i understand all of that, but the thing is, there are no 3.45's listed anywhere. the only thing i could find is that it had to have come out of a ford rear end?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear end
positive its not a 3.42
haha, once i get back into the gears, i will check again, but i have everything written down to what it was exactly and its a 3.45 ha
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Rear end
Tyer, look on the bottom of the rear or under the "pumpkin", does it say borg warner? if so, someone swapped in a 9 bolt down the line.
Re: Rear end
its a ten bolt for sure, when i did gasket work, i made sure to get the right gasket, chevy ten bolt. this is some crazy stuff.. regardless of being able to identify the gears, i love them. i would tell you when it shifts and what rpms, but im short all my gauges haha.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
