TV Cable adjustment issue???
Old Jun 13, 2010 | 09:57 AM
Justin385RS's Avatar
Car: 91 Camaro RS
Engine: Fast Burn 385 w/NOS
Axle/Gears: 3:73
I ve been tryinf to adjust my TV cable becuase my tranny is shifting a little weird ( 700r4). I push the D button in and push the black slide all the way in ( toward the firewall). this is where it was to begin with. Then i let go of the D button and from the carb I open the throttle all the way and it does not click out at all. Just stays where it is. Am i doing something wrong? Is the cable too stretched out? I dont have the original motor. I have a 91 RS w/ a FASTBURN 385 and Holley double pumper, it has B&M TV cable adapter on it , and i also have a B&M megashifter if this info helps at all.
Old Jun 14, 2010 | 09:07 PM
Car: 91 Camaro RS
Axle/Gears: 3:73
Re: TV Cable adjustment issue???
Any one with any ideas??
Old Jun 14, 2010 | 11:04 PM
gmonly's Avatar
Car: 88 chevy k1500 reguar cab, 8' box
Engine: super duty TBI 350
Transmission: 4L80
Axle/Gears: posi 3.73
did it work before?
if it did, check to see if it came apart in the trainy end.
if it has not worked before, it looks like the bracket is not far enough back from the carb.
also, is the cable kinked?
looks like it is in a angle
Old Jun 18, 2010 | 07:16 PM
Car: 91 Camaro RS
Axle/Gears: 3:73
Well, i tried different positions to see if i could find a good spot and now no matter where i position the slide,even if i put it where it originally was the tranny slips really bad. I barely made it home. I took it down the road a mile or so and had to creep home. I dont know what is going on?? anyone??
Old Jun 18, 2010 | 08:45 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
So can you go to WOT or not ?
Old Jun 19, 2010 | 08:08 AM
Car: 91 Camaro RS
Axle/Gears: 3:73
when im driving it? no, it will slip. I can turn the throttle plate to WOT manually when the car is not running, if that is what u meen? when i bought the car it was shifting, just seemed like it slipped sometimes, and the shifts were soft. I was told it has a TCI stall converter and a shift kit. Let me get some better pics.
Old Jun 19, 2010 | 09:17 AM
Car: 91 Camaro RS
Axle/Gears: 3:73
Some more pics if they help.
Old Jun 19, 2010 | 01:16 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Sounds like its time for a rebuild. Especially sinces it was slipping to begin with.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
dhonda200
Aug 11, 2015 11:50 PM
