'83 non-World Class T5 issue
Old Jun 20, 2010 | 06:57 PM
Daytona_83's Avatar
Car: 1983 Pontiac Trans Am "Daytona"
Engine: LG4 305 V8
Transmission: T5 5-speed
Alright, so we got the transmission out of the car and replaced the clutch fork, pivot ball, throwout bearing and input/output shaft seals. We put the trans back in the car and was trying to adjust the clutch (it's an 83, so it's mechanical, not hydraulic) and whenever I pressed in the clutch, the linkage would push the fork back, but then when I'm nearing the full throw of the pedal, the fork drops down about a 1/2 inch, which is not normal. The fork is supposed to move forward/backward, not down. So that is where we are stuck...why is this happening? Anyone have any suggestions?
Old Jun 20, 2010 | 07:35 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: '83 non-World Class T5 issue
it maybe needs to be bleed properly?...
Old Jun 20, 2010 | 08:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
reading FTL!!! mechanical setup, not hydraulic
Old Jun 21, 2010 | 12:50 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Take a look at your z-bar and associated parts.
https://www.thirdgen.org/forums/post...914-post2.html
Old Jun 21, 2010 | 04:54 PM
Daytona_83's Avatar
Engine: LG4 305 V8
Yeah, we were thinking it might be in the linkage somewhere...either something broke or is bent maybe. Thanks for the write-up!
Old Jun 21, 2010 | 05:23 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
My guess would be the fork and fork pivot . I don't think that the throw out bearing could go too far forward and slide off of the sleeve on the input shaft, or could it? Any way, it sounds like you'll be taking things apart one more time.
Old Jun 21, 2010 | 05:25 PM
Daytona_83's Avatar
Engine: LG4 305 V8
Well we just replaced the fork and pivot ball with new parts. I don't know...we're thinking it might be in the clutch pedal linkage around the Z bar area.
Old Jun 21, 2010 | 06:24 PM
Hubes's Avatar
Car: 85 Z28
you probably don't want to hear this but if you took the tranny back out you could probably see whats going on
Old Jun 22, 2010 | 04:26 PM
jmd's Avatar
jmd
You're welcome. Update us as you've time. I bet your weather is getting really nice to dig into projects like this.
Old Jun 22, 2010 | 06:45 PM
Daytona_83's Avatar
Engine: LG4 305 V8
Well it's been kinda unpredictable lately...lots of rain with spots of sun. I told my friends that are helping me to finish the truck that they are restoring before we rip into the Bird again...then there will be no distractions.
mrogers
May 14, 2023 04:31 PM
Rogue86
Mid-West Region
Mar 19, 2008 12:30 AM
85f-bird
Feb 20, 2005 04:14 PM
Mad-Mic
Jun 22, 2004 10:39 PM
