Changing the gear oil by sucking it out the fill hole
Old Jun 21, 2010 | 12:38 AM
joshwilson3's Avatar
Old Jun 21, 2010 | 07:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Changing the gear oil by sucking it out the fill hole
There's only about 2 to 2-1/2 quarts of oil in the diff. A washer fluid jug with the side cut out of it will be enough to hold all the oil.
Although trying to suck it out might work, it won't get it all. Also when removing the rear cover to drain the oil, you can get most of it plus clean out any contaminates in the bottom of the housing.
Old Jun 21, 2010 | 07:28 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
don;t take the cover all the way off in one shot leave a couple bolts in around the top and pry the cover till it moves a little so you can control the flow of oil out of the cover and then like alky said check for contaminates and metal on the bottom
Old Jun 21, 2010 | 12:40 PM
Hm. Yeah, really didn't want to mess taking the cover off and mess dealing with a cover leak or something. I'm sure it would be good to take the cover off to wipe the bottom, but no one does that on the C4 Corvette as you have to pull the differential out of the car. So, they just suck it out the fill hole.
Old Jun 21, 2010 | 02:41 PM
tom86iroc's Avatar
Car: 1986 iroc
totally up to you anytime i've ever taken a rear cover i've never had it leak it's all in the prep cleaning of the rearend cover always let the silicone setup with the cover on the rear for an hour before you add oil to it
Old Jun 22, 2010 | 12:56 AM
I don't use RTV as a gasket or on my gaskets. A dry paper gasket is what I use. Though I prefer a rubber gasket like the rubber Felpro transmission gasket. No clean up next time.
Though, you have to watch what gear oil you put in if you use that stuff. As Valvoline say their synthetic gear oil will eat silicone. Makes you wonder if other brands of synthetic gear oil will also eat silicone. Which is why I went with the regular Valvoline gear oil in the Vette.
Old Jun 22, 2010 | 01:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ThreeBond1194
bettter then any silicone as it a semi dry liquid gasket, it will move with parts as they heat n cool, where once silicone is set, thats its................
Its like the stuff they use between engine cases on motorcycles, where a paper gasket or silicone couldn't last near forever and not leak from all the heat cycles.
But funny haha they still use paper on side covers, gotta sell ya parts sometimes
Old Jun 22, 2010 | 11:18 PM
Old Jun 22, 2010 | 11:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally Posted by joshwilson3
That looks like some special order stuff.
Yes and no, but yes you can't run down to the corner to get some as they want to sell you RTV instead.
YamahaBond4 was just as good but they stopped making it, so no quick trip to a bike shop.
But if ya do order, get 2 tubes as it wll be your goto goop from now on once you use it.
Though RTV does have it place, like the china wall on a intake where you need a big thick globbin bead.
Old Jun 22, 2010 | 11:39 PM
I doubt I would use the stuff again. As I've never needed stuff like RTV before. So, it would be cheaper to just get the $5 gasket than probably spend $20 to get some one time use sealant/gasket out of a tube.
Old Jun 23, 2010 | 11:21 PM
Old Jun 24, 2010 | 01:00 PM
I decided to go ahead and pull the cover and wipe it out since it has 175k miles and I don't know if it has been done yet. I went ahead and sucked out the fluid so I don't have a mess when I remove the cover.
I picked up a Felpro gasket. As in my parts book, it shows a gasket to be used. And there is a gasket on there now with no problems. So, I figured I'd stick with OEM.
Old Jun 24, 2010 | 10:07 PM
What is the torque spec on the differential cover bolts for a 10-bolt?
In the middle section of my Haynes book, it shows 20 ft/lbs. But at the front of the book, it says 30 ft/lbs.
And it looks like the fill plug gets 20 ft/lbs.
Old Jun 27, 2010 | 06:13 PM
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
BurlyChev
Aug 16, 2015 09:08 PM
