non lockup converter info please
Old Jun 27, 2010 | 06:02 PM
AKATDOG's Avatar
Car: 84 Z28
Hi, the guy that built my engine recently put a non lockup converter on the trans, its a 700r4 and i didnt even know until i noticed the switch in the engine bay unhooked, now what is the easiest most reliable thing i can do to prevent over heating? thanks
Old Jun 28, 2010 | 06:56 PM
AKATDOG's Avatar
Car: 84 Z28
Re: non lockup converter info please
anyone? the transgo shift kit (sk700) says
"Corrects/Prevents/Reduces: Absolutely prevents Stuck TV valve. Late shifts, downshift clunk; 3-4 clutch failure; no lockup; 2-4 band failure; early shifts; 1-2 slide/slide-bump; reverse delay hot; 2-3 cutloose;
reverse clutch failure. 83-87:
Kit lets you make Converter lockup-no wires needed."
will this kit also make my non lockup converter lockup?
Old Jul 6, 2010 | 05:02 AM
AKATDOG's Avatar
Car: 84 Z28
still need some advice here guys...
Old Jul 6, 2010 | 06:24 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
If you put a non lock up converter in your car you cant make it lock up. Buy another converter.
Old Jul 6, 2010 | 10:53 AM
AKATDOG's Avatar
Car: 84 Z28
are there any mods that can be done so it doesnt burn up the trans?
Old Jul 6, 2010 | 11:29 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Purchase a good size external trans cooler to go inline with your current system (through the radiator). A temp gauge to monitor heat is also a good idea but not necessary.
Old Jul 6, 2010 | 04:18 PM
AKATDOG's Avatar
Car: 84 Z28
before i buy a cooler is there such thing as too much cooling? im looking at one thats for 26,000 GVW will this be fine or should i go bigger?
Old Jul 6, 2010 | 04:52 PM
da.slyboy's Avatar
Nope, the bigger the better. Run the fluid into the cooler before the radiator, this helps warm up the fluid faster (on cold days) and keeps the temp stabilized.
Old Jul 6, 2010 | 05:37 PM
AKATDOG's Avatar
Car: 84 Z28
perfect, thanks
Old Jul 6, 2010 | 07:53 PM
AKATDOG's Avatar
Car: 84 Z28
looks like im gonna get the Tru-Cool max, GVW is 40000, unless anyone knows of a better one for cheaper?
Hotrodboba400
Dec 10, 2019 07:07 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
89fast5oh
Sep 8, 2015 09:55 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
