Difference between the 86 and the 90 tranny?
Old Jul 12, 2010 | 10:00 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hello all, i have an 86 camaro and i also have an 90 camaro that im using as a parts car, i have been debating on wether to swap over the tranny from the 90 and putitng it in my 86 because i have heard there are differences internally between the two, can anyone post whats different before i go about swapping these around?---both cars are auto
Old Jul 12, 2010 | 11:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Difference between the 86 and the 90 tranny?
There were upgrades in the later years - the internals were beefed up a bit, but what exactly it was I don't know. And I'm not sure if it was done on the V6 trannies or just the V8 trannies.
Old Jul 12, 2010 | 11:18 PM
Engine: L31 350
is there any way to reaserch this? or should i just wait for people to give alittle more info?
Old Jul 13, 2010 | 10:16 AM
Car: 1992 RS
Engine: Carbed 350
There's a write-up, but it does not state whether the improvements were on all trannies or just the V8 trannies. I always assumed it was discussing the V8 trannies since the improvements seem to be stronger components - but may have well been all of them - I just don't know and haven't seen any further write-ups about it (although since I have a 1992 car I haven't really been looking).
https://www.thirdgen.org/replace-700...c-transmission
Old Jul 13, 2010 | 11:12 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
If your swapping complete units the 90 will be fine as long as the electrical plug on drivers side is still the 4 pin square design. if it is the round one it wont connect properly.
Old Jul 14, 2010 | 09:18 AM
Engine: L31 350
explain what you mean by the complete unit? also couldnt i just splice the connector heads over from the cars if they are different?
Old Jul 19, 2010 | 04:15 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
They changed the spline count on the shaft from 27 to 30. Dont remember which year, I thin 87 and up have 30 and 86 down have 27. Just have to use the right torque converter.
Old Jul 19, 2010 | 04:36 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
my 86 iroc has a 30 spline input shaft, then again i dont believe its the original tranny either. i think it was out of a monte carlo, because the ears on the sides had been milled off to fit in the tight clearance of a camaro.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
