"1991 formula 350 tpi 700r4" Tourque Converter??????
Old Jul 31, 2010 | 11:47 AM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
Im in need of some help, i have a 91 formula with a 355 tpi motor here`s the upgrades-- 355 fully rebuilt with flattop pistons, lt4 hotcam, 9.7 to1 compression, 083 heads ported and polished with 2.02 1.60 valves, 58mm throttle body, runners, headers with dual cats and flowmaster exhaust, 4.10 gears in the rear posi. cutom tunned. Hers the problom, i had the 700r4 fully rebuilt with all the updates and heavy duty stuff but i blew the new B&M tourque converter allready. My question is should i go with a lock up tourque converter or non lock up, and how much stall would be good for my application?
Old Jul 31, 2010 | 12:48 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: "1991 formula 350 tpi 700r4" Tourque Converter??????
You probably went with the TorkMaster series because it's cheap, when you shoulda paid more for the Holeshot series.
okfoz
Mar 9, 2017 02:35 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
