HELPPPP!!!!
Old Jul 31, 2010 | 04:52 PM
ridingdead1984's Avatar
HELPPPP!!!!
im swaping my t-5 for a th350 and i sold the t-5 and there just waiting for me to pull it out but i cant seem to get the clutch pedal and the slave cylinder out. does anyone know what i have to do to get it out
Old Jul 31, 2010 | 04:55 PM
Re: HELPPPP!!!!
and do i have to get a different starter cause the flywheel didnt fit
Old Jul 31, 2010 | 05:17 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: HELPPPP!!!!
The clutch pedal is attached to the brake pedal, its one assembly. You may have to take the bolts out of the brake booster to pull the pedals out. The slave cylinder is bolted to the bellhousing and simply comes off with 2 bolts. The clutch master cylinder is held on by a U-bolt, the nuts are on the inside of the car holding the pedal assembly to the firewall.
Old Jul 31, 2010 | 06:18 PM
Re: HELPPPP!!!!
how do you get the resoiuir out?
Old Jul 31, 2010 | 07:41 PM
Re: HELPPPP!!!!
Resevoir?
2 bolts hold it to a metal bracket attached to the brake master cylinder.
Old Jul 31, 2010 | 09:03 PM
Re: HELPPPP!!!!
but its under the brake booster so do i have to take that off cause i couldnt get my hands on it
Old Jul 31, 2010 | 09:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: HELPPPP!!!!
sounds like you mean the master cylinder for the clutch. Its bolted to the fire wall, under the dash, behind the pedal, you will see that cylinder coming through and attaching to the pedal. On either side of that cylinder, are 2 nuts. Remove them, unclip the pushrod from the pedal, then you can pull it out through the engine bay.
there is room for your hand in there, unless you have REALLY REALLY large hands
Old Jul 31, 2010 | 09:41 PM
Re: HELPPPP!!!!
yeah i cant even see the master cylinder for the clutch but i know where it is
COTY'S IROC-Z
Sep 14, 2010 08:00 AM
mikemazz
Mar 6, 2009 07:30 PM
1montess
Mar 26, 2008 06:50 PM
GoldenDrako
Oct 24, 2006 01:00 PM
GoldenDrako
Oct 24, 2006 10:14 AM
