Rearend swap
Old Aug 14, 2010 | 03:18 PM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Rearend swap
I got a 84 z28 with a non posi rear end.....so if I go the salvage yard, what vehicle would bolt up? S10, isuzu rodeo, c10, silverado? I'm really only worried about leaf springs because my camaro has shocks and not leafs so any help would be appreciated.....Hoorah
Old Aug 14, 2010 | 03:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rearend swap
you can only use a rear from a 82-92 f-body (camaro firebird), keeping the stock width, or a 97-02 4th gen f-body rear, but they are about 1.5-2" wider on each side.
Old Aug 14, 2010 | 03:31 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Re: Rearend swap
Wider how? Wheel spacing from the frame? All I want is positraction but I thought the driveshaft would fit the same.....it's the bolt to the body I'm concerned with also. But why stick with camaro and firebird rearends?
Old Aug 14, 2010 | 04:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Rearend swap
wider side to side, so your wheels will sit 1.5-2" further out from where they sit now. driveshaft will still work.
you can only use those rears, because they are the only gm rears setup with the torque arm setup that the 3rd and 4th gen use. the torque arm is the unique part. There are aftermarket rears available from Strange, Moser, Currie, ect, is the chevy 12 bolt, ford 9" and dana 60 variety, but are all over 2k for the setups.
Old Aug 14, 2010 | 10:01 PM
big gear head's Avatar
Re: Rearend swap
The 3rd and 4th gen F body cars have a different suspension from all other cars and trucks. Just like 86 TA said, these are the ONLY factory rear ends that will work, NO EXCEPTIONS. You can get the after market rear ends if you want something stronger and have the extra money.
Old Aug 17, 2010 | 04:14 PM
91_fbird's Avatar
Car: 91 Pontiac Firebird
Engine: SMall Block 350 TBI
Transmission: 5-Speed
Axle/Gears: Stock(for now)
Re: Rearend swap
like today i bought a rear end off a 86 T/A with posi and rear discs....$150 and i have a feeling it may be built because it has a aftermarket diff cover with a drain in it and the car n the yard had gears n the boot....so its a toss up until i pull the cover n count the teeth but im optimistic....i jus had to rid of that open diff
Old Aug 18, 2010 | 01:45 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: Rearend swap
I'm thinking of going this route as well to get the gears I want. I called a couple shops in town today and they quoted me $625 & $675 to swap to some 3.73's to replace my 2.73's. That's not something the wife would go for! I had one guy say he would get me a used set installed for around $475?
A used 10 bolt is starting to become pretty appealing. It would be different if I was trying to build something seriously strong for racing.
What are your thoughts big gear head? Any advice?
Old Aug 18, 2010 | 01:56 PM
Stephen's Avatar
Car: 87 GTA
Re: Rearend swap
The stock 3rd gen 9-bolt diffs came stock with a drain plug.
If your counting teeth to get the ratio, that is the hard way. Just spin an axle and count how many times the pinion spins for the axle to make 1 full revolution. That will give you the gear ratio inside.
Old Nov 20, 2018 | 12:56 PM
JojoDacosta's Avatar
Re: Rearend swap
stay away from them Isuzu rearends, parts are hard to find and when you find them, the ring and pinion is $840.00
Old Nov 21, 2018 | 06:58 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Rearend swap
Hopefully in the last 8 years he figured it out
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
