TH 350 shift problem
Old Aug 26, 2010 | 05:57 PM
usmc949803's Avatar
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
turbo 350. every so often it seems trans isnt shjiftin or doing anything. ill have som speed up maybe 30 40 mph then rpms just go up with no speed increase. happens a few times
Old Aug 26, 2010 | 08:45 PM
usmc949803's Avatar
Car: 92 Camaro RS
Re: TH 350 shift problem
also i think there might be a "hissing" noise at times
Old Aug 26, 2010 | 09:20 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
well what I do know about the TH 350 is that sometimes the vacumn modulator goes bad, but if you hear a hissing noise the vacumn line that runs to it may have a tear or hole in it.(Its best to check all the vacumn lines while you are there.) Replace the vacumn line, it is almost alway rubber and with new line it is cheap to do and may just fix it. just track it from the transmission all the way up to the engine. The module is on the passanger side of the tranny and will have a vacumn line running from it. it is ez to spot. If that doesnt fix it let me know.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
