identify a t5??
Old Sep 2, 2010 | 01:24 PM
sedorbrian's Avatar
identify a t5??
i need a t5 for my v8 camaro, i believe that means i need a 27 spline t5. Is there a way to identify one of these at the junkyard without ripping the drivetrain apart?
Old Sep 2, 2010 | 01:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: identify a t5??
Check the stickies at the top of the page.
JamesC
Old Sep 2, 2010 | 01:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: identify a t5??
The metal tag held by a tailhousing bolt will have a 1352xxx number.
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
Some later shifter covers had a decal with the 1352xxx number, but those are interchangeable. I've bought a 1988 box that had a 1986 shifter cover.
Old Sep 3, 2010 | 06:24 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: identify a t5??
Honestly, if you find a manual thirdgen in the junkyard, pulling the trans will take you maybe 30 minutes if the car is already sitting on blocks/tires/whatever. I pulled a T5 out of an 85 a few weeks ago and it was EASY, much easier than I thought it would be. If it has the 26 (or so) splines, its from a V8, if its only got like 14 (can't remember exactly), its from a V6 originally.
Either way, if its already in the thirdgen, chances are good the torque arm mount is still there, so obviously it should fit in yours.
Old Sep 3, 2010 | 11:43 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: identify a t5??
hi , i can get a T5 but with a repair needed for $50...the guy says the group gear is broken inside...is that the cluster gear?...will it be expensive to repair that piece?..thanks,
Old Sep 3, 2010 | 05:44 PM
jmd's Avatar
jmd
Re: identify a t5??
Probably.
Probably.
Try the gear box or d&d to price the part new. Then look for used.
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
