4th gen 10 bolt for my 3rd gen? And how to tell if its still good?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
this guy i know has a 10 bolt posi from a 1998 z28 camaro for only $100.00 but he doesnt know the history of it. Is there any way too check and make sure that everything is good on it before i buy it?
Re: 4th gen 10 bolt for my 3rd gen? And how to tell if its still good?
I just made a comment on my thread to someone about this very issue. I have an issue spending money on a used rear end when I don't know what may or may not be wrong with it. I hope we get some good answers in here.
Car: 1991 Bird
Engine: Goodwrench 4bolt 357 bore vortec
Axle/Gears: 10 bolt posi disc w/3.23
well the 98 sould be an LS1 car so its a pretty decent deal. just make sure both wheel turn the same direction and hold the pinion and turn side to side to check for play. for 100 i would buy it.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
hold up, if its a 98 it should have a zexel torsen in it, and IIRC the torsen unit acts as an open diff when its up in the air, theyre a worm gear set up so it wont actual lock into place until the gears step up from torque load
Q: Fill in the blank
A: Take off the cover and look
Q: Some other question
Q: But.....
Q: What if....
I'm struggling here, gotta maybe check with my guru; but, do I begin to detect a pattern? NAAAAAAAHHHHH..... just, the drugs I'm on aren't good enough. Lemme go snort/smoke/shoot/eat/drink/whatever some more, maybe I'll eventually "get it".
Q: But.....
Q: What if....
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
A: no offense to the OP but now everyone knows what they're looking for, most people pop the cover, see that its there and call it a day which isn't helpful.
My advice is the same as his, just look, make sure the wheels spin when you turn the pinion, check for slop or any play in it, also when you pop the cover check for metal shavings etc, anything out of place.
All humor and common sense aside, but in the same vein:
If you take the cover off and look but don't know what it is you're seeing, TAKE A PICTURE (a good clear one, not some crappy cell-phone blob of gray fog) AND POST IT here. We can help you identify what you're faced with.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
