Help! 700r4 rebuild NO GEARS!
Old Sep 6, 2010 | 08:34 PM
IWANNAROCAGAIN's Avatar
Car: 91 Z28 Convertible
Axle/Gears: 3:42
I just finished rebuilding my 91 700r4 this weekend, installed it today, everything hooked up and went in fine,
but I have no forward or reverse gears! I put 4 quarts in pan to start and 1 in converter before I installed into case,
any help would be extremely appreciated!
I also added a modified transgo jr shift kit,
thanks
Old Sep 6, 2010 | 09:52 PM
wddavis's Avatar
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
Re: Help! 700r4 rebuild NO GEARS!
check on a spec, if I rember correctly, a fresh build should take 11 qts. 4 would be a service.
Old Sep 6, 2010 | 09:58 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
You need to add more fluid for it to work, if it is a brand new converter and all fluid drained from the trans oil cooler, you will be looking around 10 -11 like wddavis stated.
Old Sep 6, 2010 | 11:07 PM
Axle/Gears: 3:42
I actually have ten total, I started with 4 in case and I put 1 quart in converter, and i added 5 more in the case, i can also pull it out of park, seems like my shift linkage is out o wack, any ideas on that?
Old Sep 6, 2010 | 11:13 PM
Axle/Gears: 3:42
Atleast it staying in park! This is my 1st rebuild, I even changed the sun shell to the "beast", and used z-pack 3-4 frictions and updated the pump to 13 vanes, followed everything from the book and DVD, but now I'm not sure where to go with this, torque converter is rebuilt as well, carbon woven and furnaced brazed, I didn't skimp on parts or atleast don't think I did
Old Sep 7, 2010 | 10:58 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
So what is your fluid level running then? Being less than a quart low on fluid in these transmissions is enough to keep them from shifting. Have you done a pressure test, to see if your pump is working?
Old Sep 7, 2010 | 11:19 AM
Axle/Gears: 3:42
I'm at 10 quarts, hard to tell because the car I on a slanted driveway, so on the dipstick it shows just about at the full cold marker, but another thing I noticed is that the engine is running hot and I had put a 160 fail-safe thermostat in two months ago, not sure i it's related.
I'm trying to get my hands on a oil pressure gauge, do you know where I can get one?
Old Sep 7, 2010 | 11:32 AM
da.slyboy's Avatar
I realized you have added 10 quarts, but that still doesn't determine if you are at the proper level. Start you car and let it warm up, then on a level surface, check the fluid level. It's the only way to truly know if you are full. There was a point in my rebuild that I didn't think I would ever add enough fluid (13.5 quarts which included an external cooler). Also what temperature do you consider your engine to be "running hot" If you are referring to the pressure gauge for the transmission some auto parts stores might carry them, but you will have better luck ordering them online (amazon, summit, even ebay)
Old Sep 7, 2010 | 11:41 AM
Axle/Gears: 3:42
Oh ok I'll have to check on the accurate level. If the pump or the converter weren't working then wouldn't the fluid level be way to high? The engine is running around 240, but to me that seems high considering the thermostat should be opening up at 160-170, right? the motor is a tpi and know they tend to run hot.
Do you know what specific kind of oil pressure gauge I'm looking for?
Old Sep 7, 2010 | 11:48 AM
Axle/Gears: 3:42
Do you know if this gauge would work? Actron ACTCP7828
It's a fuel pressure gauge, but does that matter?
Old Sep 7, 2010 | 02:48 PM
Axle/Gears: 3:42
Would it do any damage to the transmission if the fluid level is too low?
I'm going to check the pressure level in a little while. I will post my findings thereafter
Old Sep 7, 2010 | 04:48 PM
Axle/Gears: 3:42
Ok this sucks, looks like I have to order a oil pressure tester! It amazes me how you can't get parts and tools around here!
Any other options in the meantime?
Old Sep 7, 2010 | 04:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A transmission pressure gauge is usually 300 psi. I wouldn't put a fuel pressure gauge on it.
If you removed/replaced the boost valve a common issue is not getting it installed correctly. This will cause no line pressure in the tranny.
What happens with the boost valve is that there appears to be a snap ring location that isn't. It is further down then the real location. So once the trans builds some line pressure the boost valve assembly ends up in the pan.
The the line pressure goes away and the car won't move.
That is where I would start.
RBob.
Old Sep 7, 2010 | 04:56 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
my 700r4 held 16 qts......lol i dont see how your guys take so much less
Old Sep 7, 2010 | 06:03 PM
AaronIROCZ's Avatar
Did you hook up the manual shift valve to the shift linkage?? It is a 1.5 inch long rod that you have to install while attaching the valve body to the trans that is very easy to forget, I know I have.
Old Sep 7, 2010 | 06:49 PM
Axle/Gears: 3:42
Yeah, I actually almost forgot to put that on! But it is on, just seems out of adjustment because I can pull it out of park without depressing the button, tried to adjust the shift cable a few times but it still does the same thing!
But I loosened one of the trans cooler lines and when I started the engine fluid started pissing out, so I am assuming the pump is working, I have to order a oil pressure tester to check the actual pressure,
one thing I did notice when I shift it through prnd321 is that the rpm's drop from neutral to drive gears, but no change in reverse, but car still doesn't move!
Old Sep 7, 2010 | 07:06 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
you always need the button to get out of park.
Old Sep 7, 2010 | 07:48 PM
Axle/Gears: 3:42
That's true. But for some reason it not locking in park, I don't know how else to adjust the cable to make it lock in park!
Old Sep 7, 2010 | 07:53 PM
Maeryk's Avatar
Car: 89 Formula 350
Transmission: auto
I may be off on these trannys, but in my experience, park is actually a pin that drops into the shaft, and "locks" the tranny. (which is why they recommend a tranny job after your car gets hit in "park", it often snaps the pin off). So I'm wondering if something is lined up wrong?
it may just be an adjustment as well.
Old Sep 7, 2010 | 08:45 PM
Axle/Gears: 3:42
If the torque converter wasn't set right then would there be any flow of fluid throughthe cooler lines?
Old Sep 7, 2010 | 08:47 PM
Maeryk's Avatar
Car: 89 Formula 350
Transmission: auto
again.. last time I worked on a tranny it was a mid 70's pontiac le-mans sometime in the early 90s.. however.. if the converter is spinning, you should have pressure.. it might be as simple as a cable or shifter adjustment? Others probably know better than I.. and Chilton's/Hayne's knows, as well.
The main issue with the converter is getting it balanced to the flywheel. If it's off, your call will feel like a washing machine on an unbalanced spin cycle forever.
Old Sep 7, 2010 | 08:51 PM
Axle/Gears: 3:42
RBob.
I'm goin to pull the pan tomorrow afternoon to check if this snap ring is not in the right location,
and then I can see how many quarts of fluid are in the pan to see if the fluid is circulating,
Any way to test the converter in the trans to see if it is locked in? Is was back around an inch from the bellhousing, but I don't remember if it clicked 3 times or not
Old Sep 7, 2010 | 08:55 PM
Axle/Gears: 3:42
I also think my tv cable is way off, that would cause a high idle if it's too tight? My neighbor tried to adjust it, said it was self adjusting,
I have to address the park issue as well, the haynes says it's adjusted through the manual linkage, not sure how it works
Old Sep 8, 2010 | 08:43 AM
da.slyboy's Avatar
So are you talking about just the shifter not clicking into park, or the transmission going into park? Just to clarify, do you have any gear (reverse, manually shifting 1-4)? Can you lift the rear wheels off the ground and get them to move at all in any gear? It does sound as if the pump is working, so it might regrettably be time to go back and double check everything in the valve body.
If you still want a pressure gauge you can get a kit at http://www.amazon.com/Advanced-ATD-5...3953265&sr=1-1
Old Sep 8, 2010 | 08:48 PM
Axle/Gears: 3:42
Ok so I found the boost valve in my pan! This time I made sure the snap ring is in the correct groove! Thanks rbob,
goin to fill it back up and try again!
I'll update you guys in a few,
thank you all for your help and input!
Old Sep 8, 2010 | 08:50 PM
Axle/Gears: 3:42
Oh I forgot to ask if you guys have any advice on how to adjust the tv cable?
I think that is off because the engine idles high ever since my neighbor tried to adjust it
Old Sep 9, 2010 | 06:53 AM
Axle/Gears: 3:42
It was the boost valve! The car now moves, but when I try to kick it down it doesn't go, now I have to adjust the tv cable, anyone know how to adjust this cable?
I want to thank everyone for their help, this was my first transmission rebuild and I'm extremely satisfied that my rebuild was a success!
Next is goin to be adding 3:73's!
Old Sep 9, 2010 | 10:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are many ways to adjust the TV cable. However, this is my preferred method.
Engine off.
Find the D tab on the cable housing and depress it.
Push the cable housing toward the front of the car.
Wire the throttle so that it is wide open. Can also get someone to hold it wide open.
Depress the D tab and pull the cable housing towards the rear of the car. Until the TV cable between the housing and throttle linkage is taunt.
Release the D tab locking the adjustment.
From this point you can further adjust the cable. But, no more then two clicks in either direction. Further adjustments are made doing a 2-1 kick down test.
To test the adjustment it is along the lines of pulling out with moderate throttle, then once the trans shifts into 2nd, mash the gas pedal. It should immediately kick back down to 1st.
RBob.
Old Sep 12, 2010 | 07:42 AM
Axle/Gears: 3:42
Ok so I did the tv cable adjustment, the shift kit I used I believe eliminated the part throttle downshifts. I tried the 2-1 downshift, if I floor the gas it kicks downs and takes off like a bat out of hell! But only when I slam the pedal to the floor,
does that seem right?
Old Sep 12, 2010 | 09:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good to go.
RBob.
Old Sep 12, 2010 | 10:10 PM
Axle/Gears: 3:42
Awesome! Thanks for all your help!
So I Think my first 700r4 rebuild was successful!
Now I have to figure out how to do the gears in the rear!
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
someone972
Aug 30, 2015 12:52 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
hokis
Aug 9, 2015 03:57 PM
