Do I need a new speedometer cable?
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Hey guys,
I have a 1986 Chevrolet Camaro Z28, 305 Carb with a 5spd manual transmission.
It currently has the stock 85 mph speedometer in it. I'm trying to find out if I get an Iroc 145mph speedometer, can I just swap it out and the gears in the speedometer will handle displaying the correct mph, or do I need to replace my speedometer cable as well?
Thanks!
Thanks!
Car: `86 SS / `87 SS
Re: Do I need a new speedometer cable?
The mechanical. speedo gears in a GM car transmission spin the cable 1001rpm at 60mph.
No change needed. Just swap the speedo.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As jmd mentions, swap the speedo head (to avoid any possible electrical issues). I'd clean the cable. Following are a couple of links with how-to's:
https://www.thirdgen.org/forums/inte...eedo-woes.html
And I'd fix the trip odometer, which is no doubt broken:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
JamesC
TMZIrocZ350
Oct 7, 2015 12:09 PM
