How do I tell if its just the seal leaking?
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have some pretty substantial leakage from my differential. It is coming out from the pinion area I think. I am planning on changing it this weekend. How do I know if the bearings are still good. I plan to change the seal, gasket and fluid this weekend. I would like not to have to rebuild my rear end.
How can I tell if it really is just the seal? How do I know if the bearings are still good?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How do I tell if its just the seal leaking?
It's fairly common for oil to work its way through the
splines of the yoke and leak out around the nut-
sometimes you can clean that area real well with carb
cleaner then daub oil resistant silicone rubber in
there.
First though better check the tightness of the pinion
bearings-if the yoke moves up+down or in and out
any the bearings are too loose..
Also feel for any bearing roughness when you rotate
the yoke.
there.
the yoke.
Car: 1984 Z28 T-TOP
If the pinion is secure and there is no play, could it be just the seal?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bubbaz28
Sep 18, 2015 02:09 PM
