Identify this flywheel?
Old Sep 20, 2010 | 08:10 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Got this from another member, surfaced, definitely lighter than stock, now ive been told its a fidanza but when i look up their products i cant find one thats similar, maybe someone can tell me what it is exactly, i noticed the plate on the rear of the flywheel, im assuming this is for balancing?
TIA!!!
Old Sep 20, 2010 | 08:30 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: Identify this flywheel?
Maybe for a small block 400? I have a friend, who ran a standard trany behind the 400 but did not look at the flywheel.
Old Sep 20, 2010 | 08:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Old Sep 20, 2010 | 11:41 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
so does anyone know what this look like? its obviously not a centerforce, i was hoping that the offset ring gear would narrow it down...
anybody??
Old Sep 21, 2010 | 02:11 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
what is offset about the ring gear?
It's pretty obviously an LT1 T56 style flywheel.
Balance is probably for either a 454 bb, 400 sb, or 86+ sb.
Old Sep 21, 2010 | 02:29 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I wasn't sure if all the lt's were like that or if it was the design, I meant the spaces between the face and ring, I'm sure its for an 86+ sbc, but I was wondering if there was an identifable number in a common spot
Old Sep 21, 2010 | 11:33 AM
jmd's Avatar
jmd
T56 F-body LT1 is deep depth because the clutch disc sprung hub is towards the engine. The depth keeps it away from the flywheel bolts.
The ring gear is still the same distance from the crank face.
I know a Spec flywheel for 2pc seal 85-down engines has a # on it, but I'm not familiar with yours.
Old Sep 21, 2010 | 05:08 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
figured it out! turns out its an SLP flywheel, weighs about 12 lbs i believe
http://www.google.com/imgres?imgurl=...1t:429,r:7,s:0
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
