turbo 350 not shifting as hard as used too
Old Oct 1, 2010 | 07:19 PM
87irocz383's Avatar
Car: '84 Z28
Transmission: Turbo 350
Axle/Gears: 7.5/3.73 posi
I have a turbo 350 and before I took out the engine for some repairs it used to shift nice and firm hard shifts ( trans-go shift kit) it would shift so hard it would knock my foot back off the gas pedal!!! in 1-2 and 2-3. I put a stall converter in before I put the motor in also, now the trans does not seem to shift as hard as it did before the stall and motor repair. Does anybody have any ideas why or have had this problem? Any help is appreciated.
Old Oct 1, 2010 | 07:29 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: turbo 350 not shifting as hard as used too
the addition of the stall is the cause..
its perfectly normal, nothing to worry about.
Old Oct 1, 2010 | 08:04 PM
87irocz383's Avatar
Car: '84 Z28
Why would the stall affect it? How do I get them neck snapping shifts back like I had before?
Old Oct 1, 2010 | 08:13 PM
87irocz383's Avatar
Car: '84 Z28
Also, how about a full manual valve-body, do they have a nice firm hard shift? What about the vacuum modulator, wheres the best place to connect it to vacuum, under the carb on passenger side? Basically I'm looking to get them nice hard shifts back?
Old Oct 1, 2010 | 08:19 PM
On Probation
you cant...
the stall deintensifies the "bang" shifting that normally occurs with a stock converter
its the nature of the beast..stall converters have more slip/give to them, which in a way softens the shift's.
Honestly, i wouldnt worry about it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
