Is there a Thread about it????
Old Oct 30, 2010 | 07:49 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Hi there
is there a good post/thread from a trans swap?
and not and automatic to a manual !!!!
but a manual to a automatic transmission !!!
i have do al lot of research but can`t find the right info about it.
i have ask it earleyer before but still not the right answers!
so i try it one more times on this way.
maybe it is possible to make a good sticky thread for it.
I hope some people can help me.
and yes i will do a swap from T5 to TH700R4.
thanks Dennis
Old Nov 2, 2010 | 12:36 PM
Car: camaro iroc-z
Re: Is there a Thread about it????
Old Nov 2, 2010 | 01:10 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Well you would need the components that work with the 700r4, assuming you already have the torque converter, you would need a flexplate, shifter cable, shifter, the center console trim for an automatic thirdgen, You would probably need the transmission cooler line's for the automatic, tranny mount, switch the brake and clutch pedal assy for the one out of an automatic. There's a few other things but this should get you started. I'm sure others will chime in to further assist you.
Old Nov 3, 2010 | 11:05 AM
Car: camaro iroc-z
thanks, but i know the most things i need.
i thought maybe there is a thread who telling step by step how to do!
and some problems you can expect when you do the swap!
dennis
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
