cleaning debris out of torque converter
Old Nov 1, 2010 | 08:29 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
I had a new tranny fail on me which obviously sent aluminum debri all through the system including the torque converter which is new. Is there a way to clean out the converter to get rid of all the debri ?
Old Nov 1, 2010 | 08:48 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: cleaning debris out of torque converter
as far as i know.. there isnt... if i were you id get ahold of the ppl u got hte convertor from and talk to them about it
Old Nov 2, 2010 | 01:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It has to be rebuilt... cut apart on a lathe, cleaned out, welded back together, and rebalanced.
Old Nov 2, 2010 | 08:01 AM
trocustoms's Avatar
Thats what i was afraid of. Thanks for the replys.
Old Nov 2, 2010 | 08:40 PM
Sure. 2 easy steps.
Step 1. Buy new torque converter
Step 2. Turn in old ruined torque converter as core
Done.
There! that was eeeeezy, eh?
Old Nov 3, 2010 | 12:21 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if it was mine ,i'd try to flush it out-drill a drain hole of
about 5/16 in the outer edge,then flush through the
neck with solvent while periodicly rotating the turbine
and stator members-once no particles appear,tap the
hole for a thin,allen head 1/8 pipe plug apply good
sealant,install plug,stake or tack weld plug in place
Earlier this year had the opposite problem-torque
converter (aftermarket "stall")blew it's thrust bearing
and sent the debris through the tranny,had to drop
the tranny partly dissasemble and muck out the
debris,reassemble and reinstall-all good again
Old Nov 3, 2010 | 06:23 PM
Pocket's Avatar
Car: 91 Trans Am
I wouldnt suggest touching a converter with any sort of cutting tool unless you work at a trans shop
Would you shorten your own driveshaft? Grind down a crank? Same applies here
Old Nov 3, 2010 | 06:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I would stick with the crank bit lol... seen alot of back yard driveshaft jobs that well lol worked not for me but im just saying on this board I would bet money more than a handfull have made there own
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
