Fresh '94 4L60E no 3rd or 4th
Old Nov 22, 2010 | 02:43 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I rebuilt a '94 4L60E. Upon getting it installed I had someone finish up. Here is where the problem may have started. I'll try to keep the story short.
I get a call at work saying it doesn't shift at all. -> He only put in 4 quarts + 2 in the new converter.
So, things could have gone bad right there even after he added fluid.
After adding another 4 quarts it has R, 1, 2, maybe 3/4. So he took it around the block.
Upon returning it has no 3/4, just slips.
Here's what I can think of for problem:
1. 3/4 burned up since he tried putting it in gear while very low on fluid.
2. A check ball didn't release since I used Vasoline to hold them in place(I usually don't and I did this time).
3. I messed up a nylon seal on Stator or Input shaft when I replaced them.
4. I messed up a seal somewhere in the 3-4 pistons
5. Shift solenoid went bad sometime during the rebuild.
!!LAST TIME I LET SOMEONE FINISH A PROJECT FOR ME!!
So far for troubleshooting I've had him pull the trans fuse to see if that changes anything. - No change
Checked speed output connection. - No change
Going to check:
Shift solenoids
Drop valve body to make sure check ***** are free
I may have to pick up a pressure guage if that doesn't turn up anything. I really don't want to drop the trans again to make sure a seal isn't messed up but I'm prepared to if I need. Problem is that the test ports are usually really stuck in there.
Any suggestions are welcome.
Old Nov 22, 2010 | 03:44 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Fresh '94 4L60E no 3rd or 4th
my bet is going to be on a torn seal. I've rebuilt a few 700r4's and have never had a problem with vasoline for the check *****. a pressure gauge would definately give you more info but I have a feeling you will have to drop the trans again. Even if the shift solenoids were defective or mistakenly not connected, you would have a CEL telling you there is a problem. Hopefully I'm wrong but since all the other gears are working, you may not have a choice. I know it sucks but I've been there too.
Old Nov 22, 2010 | 08:05 PM
TZFBird's Avatar
Engine: 327
So I'm not very far off on my assumption. I remember being really cold, tired and grumpy when assembling the input hub/3-4 pistons. I'm sure something bad happened.
I don't think I've ever been able to get those test port plugs out before. Usually pretty corroded in there.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
IROCZ1989
Sep 4, 2015 11:54 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
