Stage 2 or 3 shift kit
Old Nov 23, 2010 | 12:50 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I was starting to look at some of these other camaros with the B&M stage 2 and 3 shift kits and noticing how well they take off and how fast they get up there. So I am wondering where (other than the B&M website) can I get my hands on the stage 3 (if not 3 then 2) shift kits? Anyone have an idea because my car is hesitant with shifting and when it does it kind of does it hard and slowly. So where do I get it? People keep talking about the stage 3s but I cant find them. By the way I have a 700R4 automatic. This video is what really intrigued me.
http://www.youtube.com/watch?v=mzyPj...eature=related
Old Nov 23, 2010 | 03:41 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Stage 2 or 3 shift kit
Summit racing carries B&M products. You also may want to check out TRANSGO shift kits, I have one and really like it. They make for a firmer shift and are better for your trans. with less slipping. Keep in mind your trans. has to be in good shape in the first place, these are not rebuild kits, just shift improver's.
Old Nov 23, 2010 | 04:16 PM
I understand they improve shifting and stuff all I am saying is it isnt shifting like I would want it to it's not that it is slipping or anything it's just I want faster shifting because when I race I will beating someone until my car has to shift then that is where I lose 90% of my races because it is so slow to shift.
Old Nov 23, 2010 | 05:08 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
def go with a trans go much better quality product
Old Nov 23, 2010 | 06:37 PM
So trans go is better then? I always hear from people how they will burn out in their camaro and they will chirp their tires going into second with just shift kits or being all stock. Considering my car is a stock 350 wouldnt it be able to do it too? People keep telling me my engine is missing and that I should replace the plugs and it will stop (still have not done it yet) so along with the type of shift kit I should get does anyone also have a recomendation on spark plugs?
Old Nov 23, 2010 | 07:02 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
ac delco
Old Nov 23, 2010 | 07:11 PM
Originally Posted by scamaro355
ac delco
Is there a certain kind of AC Delco mister big mouth?!? Just kidding about that but is there a certain kind to get?
Old Nov 24, 2010 | 06:13 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
the TransGo kit does entail some drilling of holes in the valve body itself (I'm presuming we're talking about 700R4). Also, it requires popping the servo to adjust the band.
I gotta admit the TransGo kit is very well thought-out and detailed. IMHO the instructions presume experience with shift-kit installs, but the picture explanations are excellent. the instructions also provide some suggestions for some upgrades, so don't be surprised if after getting the TransGo kit in-hand, you decide you need a few more parts.
make sure your servo cover is accessible. mine wasn't due to my LT headers.
my experience with B&M is that they don't have a "stage 2, stage 3", but their shift levels are described as street, strip, heavy duty, RV.
Old Nov 24, 2010 | 01:02 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
R43TS
Old Nov 25, 2010 | 10:45 AM
So it sounds to me like I should see if my neighbor and one of his friends could help me with it or if he knows a shop that would be able to do it. I know it is hard to answer this next question but do you think any normal shop would allow me to go out and buy the product I want installed and then still put it in for me? I know how there are a few that want to buy the parts themselves but to make sure there are no mix ups do you think they would let me? Yes it is for the 700R4.
Old Nov 25, 2010 | 11:46 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i dont see why a local shop wouldnt let you get the kit and take it in.. the might jack up the labor cost a bit on you since they wont be making any money off the parts.. but if your not comfy tearing into a valve body.. id really suggest having someone help you that has been into them before... theres not alot to them drill a few holes plug a few others.. basically your rerouting the fluid through the valve body because there were some flaws from factory
Old Nov 25, 2010 | 04:59 PM
Pro Built Automatics's Avatar
Go with the modified TransGo Performance Shift kit as it will give you smooth but quick part throttle shifts and quick and firm WOT shifts. This kit comes with the Corvette servo and the larger boost valves, and much more. Let me know if I can be of help here? Dana
Old Nov 27, 2010 | 12:58 PM
johns88z28's Avatar
Car: 88 z28
Engine: 350 jegs crate motor
Transmission: 700r4 b&m transpak and megashifter
Axle/Gears: stock posi 3.23 disk brokes
dana from probuilt automatics can help you
Old Dec 13, 2010 | 12:06 AM
Should I get new plugs first or should I get the shift kit first? My car is running rich and I have been told a few times my engine is missing so would the new plugs help fix that?
Old Dec 13, 2010 | 01:52 AM
johns88z28's Avatar
Car: 88 z28
plugs should be one of the first things to replace, dont worry about a shift kit until your motor runs right!!
Old Dec 16, 2010 | 09:12 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Swap spark plugs then do the kit , you'll love it
I have a B&M kit that was very easy to install and yes the results are great
http://www.youtube.com/watch?v=7Nwn2yEsXEA
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
