hyd TOB on borge warner T5 trans???
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
im wanting to install a hyd tob on my t5 transmission in my 83 z28 camaro, but i dont know which one to get or go with i have be doin some researching and i had come across 2 setups one is just a tob and the other is a complete kit with m/c, no can i use a factory m/c with a hyd tob or should i just spend the money and get the full kit. also ill be using a Mc Leod Sfi bell housing for the 82-83 camaro.
which would be best to do.
thanks.
thanks.
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: hyd TOB on borge warner T5 trans???
I am guessing you have the mechanical linkage clutch setup. I just converted my 83 to a 5spd, but I went with a later model 87 tranny. I took the clutch pedals out of an 84 camaro and used a hydro slave setup out of the 87.
Your pedals wont work if you do it that way, you will need to get the later 84 and up pedals.
I dont know about the hydro throwout bearing setup.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
P/O already swapped out the pedals on my car he was goin to use 4th gen hyd system on the car with a 6 spd swap but never got around to it and he never gave me the 4th gen hyd system, i got the m/c and everything mounted and pedals installed in the car so im all good there, ill be using a t5 out of a 87 trans am.
Car: `86 SS / `87 SS
Because it's easier to service the hydraulics, I'd use the 84-92 bellhousing and the 93-97 master / slave (braided line; master and slave are the same sizes)
Having to pull a trans. to replace a slave cylinder is a disadvantage of using a hyd. TO brg.
theshackle
Sep 17, 2020 08:26 AM
