700R4 tc lockup options
Old Jan 6, 2011 | 04:29 PM
srgould41's Avatar
I have been reading everything I can find on tc lockup. I have a 1990 trans from a Caprice(?) installed in my LandCruiser. It was converted by the PO to be a non-lockup. There is no external harness. I installed a heavy duty, lockup style converter and it stayed locked at all times. Couldn't put it in gear as the engine would slam to a stop...
I can only assume that the solenoid has had the wires snipped off. The plug housing port has a metal block-off plate in it. So there is no external wire port. I wish I had investigated this earlier when I was installing a new filter. I had forgotten all about this in my rush to get it running.
Anyway, ideally since this is installed in a 4wd trail truck I would love to be able to lock the converter from a dash mounted switch in any gear, including first, for those long downhill decents where engine braking would be very useful (better than riding the brakes all the time).
I have read that I can get it to lock in 2nd, 3rd, and 4th using the check ball method, but how about 1st also? I would not wire it through the brake light switch since I want to have it locked when braking also... I just want a simple always locked or unlocked via a switch.
Can this be done?
Old Jan 7, 2011 | 11:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 tc lockup options
You can't lock the converter in first.
Old Jan 7, 2011 | 12:47 PM
srgould41's Avatar
Can't lock it in first? That sucks... I'll be in first a lot of the time.
seiplentz
Aug 19, 2019 06:02 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
HikoriYami
Sep 21, 2015 07:11 PM
