700R4 Problem
Old Jan 11, 2011 | 04:16 PM
Dan The Man's Avatar
700R4 Problem
I have an '87 700R4 and whats happening is it goes into 1st gear but then revs up high and then I think that it skips 2nd completely. It also doesn't downshift when i go uphill, i have to pull off to the side and put it in park and turn the car off to get it moving again. Can someone please help me??
Old Jan 11, 2011 | 05:47 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 700R4 Problem
how is the tv cable geometry and adjustment?
Old Jan 12, 2011 | 11:39 AM
Re: 700R4 Problem
You know what? Thats a good question. Where should it be for it to be right on? I replaced the transmission awhile a go and just kinda bolted it on, and hoped for the best. The same thing happened with the last transmission I had in it. This is the second one i have put in it.
Old Jan 14, 2011 | 09:05 AM
torque_is_good's Avatar
Re: 700R4 Problem
here you go
http://www.73-87.com/7387garage/drivetrain/tvcable.htm
but "replaced the transmission" with what? Was it a rebuilt unit or an unknown unit namely, a used unit that you yourself had not personally owned or maintained.
Old Jan 14, 2011 | 09:18 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 700R4 Problem
well the TV cable adjustment is critical! you can burn up a transmission fast without the proper adjustment. adjust yours properly now and see how it does. if it is not working properly take it to a known transmission shop have them adjust it properly. if still not working you'll need another transmission/rebuilt
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
