350 and T5 behind it HELP...
Old Jan 11, 2011 | 07:18 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok guys i have a 83 Camaro Z28...i just finished rebuildin my engine...and i have a T5 behind it...
so can i do 2 make my tranny stronger so it can hold up 2 my 350...my engine has a mild cam and dished postons that's it...
i wana make my tranny stronger cuz i wouldn't want it 2 go out wen i drive it...
I DO NOT WANA PUT A T54 IN IT!!!...
plz help...
Old Jan 12, 2011 | 09:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 350 and T5 behind it HELP...
could always try to search a bit, this is covered thousands of times.
your only options are very expensive, and it would be cheaper to use a t56.
Use a stock replacement clutch, and dont powershift the thing or dump the clutch at high rpms and it will do just fine.
Dished pistons arent helping make power, why not keep the flat tops?, and "mild cam" is meaningless as far as power potential.
Old Jan 12, 2011 | 10:48 AM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...
and i replaced the clutch already...
would it help if i rebuilt the tranny with differentgear ratio/ bigger gears or sumthin?...
Old Jan 12, 2011 | 10:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The weak point of the T5 is the case.
Old Jan 12, 2011 | 11:11 AM
Car: 1983 Z-28
Engine: 5.7 L
o ok..
so if i rebuilt it it wouldn't help me out bcuz i still have a chance of the case goin out on me correct?....
Old Jan 12, 2011 | 01:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by 83C_CamAroZ28
o ok..
the case doesn't "fail", it flexes, which causes the gears to misaligned and shred.
Gforce makes a beefier case, which some people have use with good results. Or you can get a completely built t5 from them at the mere cost of a little over 2k.
a rebuild wouldn't hurt on a 20 year old trans, but like i said before, iof you dont abuse the trans it will be fine. Just because you are bolting a 350 to it doesnt mean its going to just blow up instantly.
Old Jan 12, 2011 | 01:19 PM
Gatormcclusky's Avatar
Car: 84 Camaro
Engine: 360
Transmission: now 350 turbo later muncy 4
it stretches,(weak)plus input shaft is smaller. I'm doin the same thing.I got a older 350(not out of a camaro)its a dirt track motor,,300 hrs heads highrise 750dbl pumper etc.. anyway im going to put it in there & take it easy til i can afford the t56..thats the only thing that makes sense,unless u want 2 put a automatic in it..GOOD LUCK!! it wont be cheap,, I remember a saying off the movie "Mad Max''.. it goes.."SPEED IS A QUESTION OF MONEY,,HOW FAST DO YOU WANNA GO''!!?? .....
Old Jan 12, 2011 | 02:19 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok thanks...i understand now...
in this case i might look into gettin t54...but I'm gona look and c if i can get a different case...
but is there a way of makinan electric speedo tranny work with an mech cable driven speedo?...
Old Jan 12, 2011 | 03:53 PM
Depends on the transmission.
"Electric" and "mechanical" are not properties of the "transmission", as such; much like, "oil brand" is not a property of "engine". You put in whichever you want.
Not sure about "T54"; never heard of that. But a T-5, you just take the electric sender thing out, and put a cable-drive "bullet" in, with the right gear. Go here http://www.transmissioncenter.net/sp...____va.htm#350 for info.
Old Jan 12, 2011 | 04:35 PM
Car: 1983 Z-28
Engine: 5.7 L
lol...o man sorry i meant t56...
Old Jan 12, 2011 | 04:40 PM
Car: 1983 Z-28
Engine: 5.7 L
thanks 4 the link i might just get the t56 later on down the road......
Old Jan 12, 2011 | 08:24 PM
A mech speedo in a T-56 is an entirely different matter. Not near as simple as in a T-5.
But yeah, I highly recommend getting one, regardless. After tearing up I lost count of how many T-5s in my car (about a half-dozen cores and probably 15-18 "rebuilds") I finally put a T-56 in it, and wish I'd done it at least a decade earlier.
Zane Story
Oct 8, 2015 12:40 PM
bluevette
Jul 22, 2014 09:50 PM
10mpg
Oct 11, 2012 10:12 AM
360Iroc
Nov 17, 2002 10:50 AM
98_1LE
Mar 1, 2001 12:44 AM
