Stuck in first gear
Old Feb 1, 2011 | 11:42 AM
Pulse31's Avatar
Stuck in first gear
Hello. My 88 Camaro has serious timing issues...chain actually jumped...visually verified. Just before I tore into it to replace the chain, the tranny started started sticking in first gear...never went to second. Is it possible that the timing had gotten so bad that the tranny wouldn't shift?
Thanks.
Old Feb 4, 2011 | 06:43 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Re: Stuck in first gear
If you are able to go fast enough for it to reach a shift point, it should shift regardless of the engine timing. One thing to check is the TV cable. If this comes out of adjustment or sticks, it would cause it to stay in 1st gear. If this happens, do not drive it AT ALL! It WILL tear up clutches and parts inside the tranny.
Check to make sure it is adjusted right first. I would see if it has slack or pulled taught with the throttle at idle, and pull on the throttle side to see if there is a spring action on the transmission end. Basically just tug on the cable and see if you can feel it being pulled back in by a little spring in the tranny. Then proceed to adjust it properly. There are instructions on doing this in the technical article section
Old Feb 4, 2011 | 10:46 AM
Pulse31's Avatar
Thank you.
Old Sep 18, 2012 | 12:46 AM
2firebirdpals's Avatar
My car is also stuck in first gear-- but I drove it around the block at 10 mph. Thats all i could do to see if I could get stuff warmed up in the tranny--Someone told me to warm her up and put her in gear and just slam the pedal to the floor to FREE UP what ever is sticking--- I "did not" to that yet. All i did was to drive in around the block very carefully and SLOW--- Did I ruin it by taking it out around the block.??? thanks Guys- I need Help real bad. John
Old Sep 22, 2012 | 03:54 PM
Well i changed dropped the pan and replaced fluid and filter/ I'll be checking that governer for excessive wear while under the car. I Hope that it was the worn Governer that caused my beiing stuck in 1st gear.
Old Oct 2, 2012 | 12:14 AM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Did any of you guys found out what the problem was? I have the same issue.
Old Oct 2, 2012 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is usually caused by the governor gear going away. They are plastic and wear away until they look like an apple core.
It is located under the dome cover, drivers side, toward rear of trans. Pop the cover off and the governor pulls out. The gear is replaceable.
RBob.
Old Oct 2, 2012 | 01:42 PM
Davidgou's Avatar
Thanks RBob, can I get a replacement at the local auto parts store or do I have to order online?
Old Oct 2, 2012 | 07:05 PM
any tips on trying to get that dome cover off??? not much room under the car -even on ramps- to swing a hammer. how about a slide hammer ?? thanks
Old Oct 3, 2012 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I get them at the Chevy dealer. Could also try a transmission shop if one is nearby. Shipping would cost more then the gear.
RBob.
Old Oct 3, 2012 | 08:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pull the cross-member out and lower the back of the trans some.
When re-installing the cover do not hit the center, hit it around the edges.
RBob.
Old Oct 3, 2012 | 09:10 PM
What works best der there-- a screw driver?? Could I drill a small hole off center and then use a slide hammer to coax it out??? thanks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
89fast5oh
Sep 8, 2015 09:55 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
