t-5 to t56 worth it?
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Is spending the $2500 or so to swap the t-5 with the t56 worth it? What do you guys think? I'm curious if having the extra gear will actually increase fuel milage? Also, can a t5 be rebuilt where the fith gear is a really high gear?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: t-5 to t56 worth it?
which rear end do you have? You'll get much better bang for you buck by swapping in a 2.73 rear end.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I hardly ever found a time to use 6th gear unless you're fumbling along on the interstate going 80MPH. It will help gas mileage, but that shouldn't be a motivating factor for the swap if that's what you're after.
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
only benefit is they are " stronger than a t5".many t-5s hold up, and apparently some don't, i haven't had any troubles,yet...
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
My T5 seems to be holding up pretty good behind the 383.
Car: 83Z28 HO
Transmission: G Force 5 speed
It'll handle more HP/TQ than it did stock. I don't know if it's as good as a 6 speed sixth gear on the road, but I normally run around 2100 rpm's at 70 mph. That's with a 3.70 geared rear....made a huge difference on the highway.
My 1st to 4th gear are stock ratio, so if I'm running it hard I wind out 4th a bit more....it's still holding fine behind my blown 408...but I have traction issues.
Axle/Gears: 273
Im looking at putting a cammed 350 in but really don't want to be getting 5 miles to the gallon.. not sure what the rear gears are but dont want them too tall with that cam because, well, car might not even move.. What's the cost to build the 5 speed with fifth bein a taller gear?
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i like this thread. im in the process of doing the same so any advice i would also love to hear. i had 330hp (305ci) to the wheels with my t-5 and it did pretty good. grinded in 2nd on hard shifts but swapped my clutch and it went away. now im looking to do a 500hp 355 with a 12 bolt and 3.55 gears. not sure how it will hold up.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This link about 10-bolts, if that's indeed what your running, might be helpful in determining gears:
https://www.thirdgen.org/forums/tran...ring-seal.html
JamesC
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
2500 for a tranny swap, heck ill sell you a LT1 FI, T56 car for 2700..drive it anywhere...its the white one in pic
skinny z
Oct 5, 2015 06:23 PM
